Quote Originally Posted by bronzemist02 View Post
Transmission shutter into gear could be pressure solenoid. Get it to a shop and get it scanned. If it is the solenoid it should throw a transmission code. The gas needle problem has to do with the fuel level sender on the fuel pump assembly in the trunk or a loose or pinched wire. You can just reset your trip computer at each fill-up and fill it at a certain mileage like I do if you don't want to replace the sender.
Yep, my car has the same problem about the gas needle, once it gets to 1/4, it goes back up until it reads full again but I'm not too worried about that, since I can go 300 miles safe with 1/4 of tank, I always put gas around 280/300 miles to be on the safe side
