Thread: Thermostat Questions
Results 1 to 20 of 37
  1. #1 Thermostat Questions
    SE Level Member mycutlassblue's Avatar
    Louisville, KY
    Hey you all I have a question.. Does anyone know what a stock 98 gtp's thermostat should run at?
    My car never seems to hit 200 always runs below the first line.
    My dad is a mechanic and has told me that It should be running a little hotter and that I could quite possibly get a little better gas mileage?
    I'm guessing someone must have put the cooler thermostat in this car at one time.
    Has anyone noticed gas mileage difference by adding a cooler one?
    Any performance changes between a hotter and cooler one?
    I like the way my car runs, but it does suck gas. Also my owners manual says they have an 18 gallon tank.. I have only been able to put in 12 gallons on the E mark.
  2. #2 Re: Thermostat Questions
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Use a scan tool to see what the temperature sensor is actually reading...you are probably operating properly at ~200°F. A lot of the temperature gauges read low.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Thermostat Questions
    Nov 2009
    Grand haven
    What mods do you have? if you are 100% stock you should be running a 195 tstat.
  4. #4 Re: Thermostat Questions
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by mycutlassblue View Post
    yes, my MPGs noticeably went down when i switched to a 180, nothing major, but i did notice it. i felt absolutely no change in performance.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #5 Re: Thermostat Questions
    Quote Originally Posted by Jakegday View Post
    Because you're not boosted nor have ported heads and a cam.
    Colder T-stat is a KR killer. Not the best one, but not a terrible one either. If you're not knocking, it won't help.
  6. #6 Re: Thermostat Questions
    Nov 2008
    Fremont Nebraska
    Because you're not boosted .
    yeah i figured that had something to do with it. but still though, numerous people on this site told me to do it anyways
  7. #7 Re: Thermostat Questions
    I hear ya, i did the same thing at first.
    Have my stocker back in till i get me some boost.
  8. #8 Re: Thermostat Questions
    West Side Michigan
    Well I had a T-Stat that was stuck open and keeping the temperature of my car below 160* (IIRC). My gas mileage was horrible... I hated it. I thought this was the price to pay for a supercharged car. I replaced the T-Stat with a new 195* failsafe T-Stat and I could really tell the difference between the gas mileage. It got a lot better to my surprise! No performance gains though... at least not that I noticed.
  9. #9 Re: Thermostat Questions
    Because you weren't knocking
    Also why would you bother with a failsafe? For a dollar or so more you can get one with a lifetime warranty.
  10. #10 Re: Thermostat Questions
    West Side Michigan
    oh, well that's good to hear that I'm not knocking.. Because I don't have a way to scan.. and don't feel like dropping $200+ on an aeroforce gauge.. even though I'm convincing myself it's worth it lol.
    And because my Autozone had a normal one for $8 and a failsafe for $11.. and that was it lol. So I got failsafe. I think it has a warranty on it.. but I forgot how long. And I was just looking at that little thermostat and wondering.. people actually drill those? Where? and for what? To get constant cooling to the engine?
  11. #11 Re: Thermostat Questions
    the 'failsafe' is a hole drilled into it so it cant ever close completely, even if it fails closed. you could have done that for free by yourself with a drill.
  12. #12 Re: Thermostat Questions
    West Side Michigan
    "Ah.. I see said the blind man to his deaf daughter.."
  13. #13 Re: Thermostat Questions
    GT Level Member Joe m's Avatar
    mesa,az
    where exactly do your drill it? iv always heard about it but never seen one up close.
  14. #14 Re: Thermostat Questions
    West Side Michigan
    Well I just thought about this.. Don't mean to argue with ya Bio, but he showed me the difference between the normal T-Stat and the FailSafe T-Stat. The normal one was just normal..
    http://tooldesk.com/blog/wp-content/...thermostat.jpg
    The Failsafe T-Stat:
    http://www.wilsonmanifolds.com/shop/...thermostat.jpg
    Those bronze added thingy's help it stay open if failed. I don't know if they are drilled or not.
  15. #15 Re: Thermostat Questions
    they apparently have a mechanism so that they fail open.
  16. #16 Re: Thermostat Questions
    Jul 2008
    sumter,south carolina
    guess ill post my question here since its already being talked about... getting ready for 3.4 setup... if i get a 180 t stat will it benefit me at all?... seeing as how i dont have fans set to be turned on at 180.
    02 GTP with mods 05 GP for DD
  17. #17 Re: Thermostat Questions
    nope.
  18. #18 Re: Thermostat Questions
    Jul 2008
    i should be alright with 195* t stat, 104's, headers for 3.4 until i get retuned? i had my tune flashed last year sometime and never got it retuned. always run 93 octane.
  19. #19 Re: Thermostat Questions
    yes, youll be fine. you could probably continue running the 195 and have no problems.
  20. #20 Re: Thermostat Questions
    Jul 2008
    thanks again Bio.
  1. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
  2. Thermostat Questions
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 07:40 PM
  3. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  4. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  5. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
