Thread: coolant problem and radiator
Results 1 to 13 of 13
  1. #1 coolant problem and radiator
    GTX Level Member colindunn's Avatar
    Aurora, IL
    okay so my car is boiling coolant out of the resivoir. the gauge inside reads cold.. i topped of the coolant and it runs fine if your driving. it boild when im stopped. i noticed the radiator fan wont turn on. i think its because the gauge is reading so low it thinks it doesnt have to turn on? but if the coolant is boiling i would think the temp gauge would read high. so im confused in what to do. think its the radiator? thermostat?
  2. #2 Re: coolant problem and radiator
    Apr 2009
    stockton ca
    change out the tstat the temp sensor and have your system flushed
  3. #3 Re: coolant problem and radiator
    Edmond
    How do you know its boiling? Sometimes you may think that, but its not boiling it simply is pressurized and sprays out when you release the cap. But if it is actually boiling I agree with the post above. Check thermostat, engine coolant sensor, and at least drain and refill if you don't flush.
  4. #4 Re: coolant problem and radiator
    St. Louis Mo.
    Quote Originally Posted by SMOKIN GTP View Post
    You can tell its boiling if the coolant bottle in the engine bay is gathering antifreeze at a large rate. When the radiator does boil, it is suppose to spill over into that tube that leads back to the external coolant tank.
    James Shafer
    St. Louis MO
  5. #5 Re: coolant problem and radiator
    St. Louis Mo.
    Also moved thread to a more appropriate section
    James Shafer
    St. Louis MO
  6. #6 Re: coolant problem and radiator
    Aurora, IL
    ive heard people say a head gasket cause of bubbles. but when its running for the first 5-10 minutes theres no bubbling. and theres no check engine light on. this is my friends car and a month ago she had the t-stat replaced by an unknown person not in a shop. if they put one in too cold would that be a cause? so if the coolant isnt "boiling" why would it be bubbling? the temp gauge in the car is reading cold. and doesnt raise. i replaced the radiator cap but no luck. you think a bad radiator is causing all of this? or is it fine but not turning on becuse its reading cold. also, if theres air in the system will it cause this?
  7. #7 Re: coolant problem and radiator
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    T stat put in backwards?
  8. #8 Re: coolant problem and radiator
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    Quote Originally Posted by colindunn View Post
    maybe it's the water pump and the fan relay that's causing your problem,something to think about
  9. #9 Re: coolant problem and radiator
    Aurora, IL
    Quote Originally Posted by PALMCASTER GT1 View Post
    i dont think it would be the water pump if the engine temp gauge reads cold. so i know the water pump is working. i checked the relay and thats good too but i might just replace it. i hate weird problems
  10. #10 Re: coolant problem and radiator
    Nov 2009
    IL
    Noticed mine will get up to over 220 and when I shut the car off the fan won't stay running. Wondering if that relay could be the issue.....
  11. #11 Re: coolant problem and radiator
    PALMDALE CA
    i got a 04 gt1 n/s and i put a new thermostat 160 , but when i did ,i thought i would make the car run cooler , but instead ,the needle would stay at the half way mark and it would go over a little after driving around,dose anyone else have this problem ???? dose the P C M have to be programed ??
  12. #12 Re: coolant problem and radiator
    Apr 2009
    stockton ca
    yes pcm has to be programmed to what ever the tstat is or else fans wont come on
  13. #13 Re: coolant problem and radiator
    PALMDALE CA
    Quote Originally Posted by TorqueAutoMotiv View Post
    that's what i thought , well it will have to be done at a later time , rt now i put the stock one back in. thanks bro .
  1. DNA Headers + Coolant Fans Problem
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2010, 10:08 AM
  2. Supercharger Oil + Coolant Mega-problem
    By element55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 05:43 PM
  3. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
  4. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  5. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
