Thread: DIC light bulb change??
Results 1 to 9 of 9
  1. #1 DIC light bulb change??
    Nov 2009
    Sheridan,Indiana
    Does anyone have a write up on changing the drivers info center light bulbs. Or does anyone know how to do this.
    I have changed the bulb out in my radio with no problems.
    This is in a 2000 GTP
  2. #2 Re: DIC light bulb change??
    CT
    what is your DIC doing that makes you want to change the bulb? Mine doesn't show anything but under sunlight or certain flash lights it shows up and works fine. If its light bulbs that would rock for me.
  3. #3 Re: DIC light bulb change??
    Nov 2009
    Sheridan,Indiana
    Mine does the same it is still working but the light bulbs are out. Anyone on this site ever changed the bulbs????
  4. #4 Re: DIC light bulb change??
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    If it's dim or gone then it's a bulb that's dying. Someone over at ClubGP did a writeup on this, it's an old link but it worked when I logged into the forum so I hope it works for you.
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    You need to get Sylvania #24 bulbs from any auto store (I paid about $5 for a pack of two), take apart the DIC, gently unscrew the blue bulb retainer, then you basically have to break off the old bulb from the blue retainer before replacing with the new bulb. I did the replacement this week with no problems.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  5. #5 Re: DIC light bulb change??
    Nov 2009
    Sheridan,Indiana
    Quote Originally Posted by nault31 View Post
    ClubGP Message Forum troubleshooting
    Thats what I was needing. Thanks alot man I knew it could be done but I needed info like this before I was going to do it. Thanks again, Eric
  6. #6 Re: DIC light bulb change??
    St. Albert
    Are there clips in those bulbs in 2000 grand prix models which dont permit you to pull the bulb out of the blue retaining socket? It looks like a #24 bulb but there is no way to pull the bulb out without breaking it. I tried everything. The part number for the bulb and the socket is 16151234 or PC119 and I cannot find them at any auto parts store so right now Im looking at a cost of around $234 for a new DIC
  7. #7 Re: DIC light bulb change??
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    The dealership should have the bulb with the blue base you were trying to pull it out of. Just bring an old bulb from the DIC with you to the dealership and they'll match it up for you. This much easier since you can just twist the bulb and the base right out. I believe there are 5 bulbs in there if you want to replace all of them at once.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  8. #8 Re: DIC light bulb change??
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by Lang67 View Post
    I got a handful of them from the pick-a-part last week for my $1 entry fee.
    I'm pretty sure pc74s will work --- but I haven't gotten one in hand yet to make sure of that.
  9. #9 Re: DIC light bulb change??
    Nov 2009
    Sheridan,Indiana
    16151234 is the part number. Dealer only item and cost 4.80ea. Dealer requires you to buy 2 at a time. They have to order them but still the price for replacement bulb and socket out weighs a new DIC. Thanks for those part numbers.
  1. How to change fog light bulb on 07 Grand Prix?
    By edmondwu in forum General Tech Discussion
    Last Post: 02-09-2013, 05:15 AM
  2. Light bulb question?
    By toolguy in forum General Tech Discussion
    Last Post: 09-10-2009, 10:50 AM
  3. change map light bulb?
    By basshead42 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:03 PM
  4. light bulb
    By Myprixxx in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2009, 06:18 PM
  5. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
