Thread: 2000 Grand Prix 3.1 fast idle
Results 1 to 5 of 5
Threaded View
  1. #4 Re: 2000 Grand Prix 3.1 fast idle
    ohio
    Quote Originally Posted by COEBAM View Post
    Is the check engine light on? Mass air flow meter, coolant temp sensor, air charge temp sensor, stick iac motor....There is all kinds of stuff that can cause this. You can clean air flow meter and throttle body. I would not advise cleaning the tps.
    I bought the car in jan. 2008 and the check engine light was on and has always been on since I've had the car. The fast idle problem started after taking the car to a Jiffy Lube for an oil change. I took it back to the Jiffy lube when the fast idle started as I thought they may have messed up the throttle linkage when they replaced the air filter. The tech hooked their diagnostic device to the car and when he reset the computer then the idle returned to normal. If it idles fast on startup, I sometimes disconnect the battery for a few minutes and I guess that resets the computer and the idle goes normal then until some future time it acts up again. Thanks for your reply.
  1. 1999 grand prix gt idle problem..
    By 1999gpgt in forum General Tech Discussion
    Last Post: 01-24-2011, 01:11 PM
  2. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  3. P0508 Idle Control System Circuit Low on 2000 pontiac grand prix
    By Bigkamp22 in forum General Tech Discussion
    Last Post: 07-17-2009, 12:29 PM
  4. HELP FAST! 2005 Grand Prix
    By gfdeputy2 in forum General Tech Discussion
    Last Post: 06-20-2008, 05:36 AM
  5. It's time to see a Grand Prix in the Fast and the Furious
    By AlmightyBirdman in forum Off Topic Discussion
    Last Post: 02-01-2008, 02:27 PM
