Thread: Dash Vibrates when AC/Heater is on High
Results 1 to 2 of 2
  1. #1 Dash Vibrates when AC/Heater is on High
    SE Level Member corbancantread's Avatar
    Feb 2010
    Michigan
    basically whats happening is (the blower im assuming) squeaks LOUDLY when on a low setting, but when Cranked to full blast my dash vibrates. Then a not so glorious "vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv" sound can be herd. It also takes a bit to feel the heat in the car.
    Its a 97' Grand Prix GTP btw..
  2. #2 Re: Dash Vibrates when AC/Heater is on High
    Guam
    You need to remove the motor and check it and the plastic "squirrel" housing, or the plastic fan. It may be cracked and out of balance, or missing pieces that broke off.
    The only way to tell is take it apart and inspect...
  1. Heater/Def/AC
    By GTPluv in forum General Tech Discussion
    Last Post: 01-22-2011, 08:49 AM
  2. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  3. gtp shakes/ vibrates
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-13-2009, 01:42 AM
  4. Need heater help.
    By the955iman in forum General Tech Discussion
    Last Post: 10-26-2009, 04:07 PM
  5. Car still vibrates....please help
    By bcrosby51 in forum General Tech Discussion
    Last Post: 03-30-2009, 04:40 PM
