Thread: Oil leak!!!!!
Results 1 to 9 of 9
  1. #1 Oil leak!!!!!
    SE Level Member musiknjoyr's Avatar
    Feb 2009
    decatur, al
    ok so all of a sudden when i stop my car to go into my house i would smell coolant....crap.....but now i am losing oil and coolant. There is what appears to be oil sittin on both sides of my engine....please dont tell me lower intake gasket...please HELP!
  2. #2 Re: Oil leak!!!!!
    GT Level Member rolyat's Avatar
    OKC
    Yup probably LIM gasket. Have any milky stuff on the bottom of the oil fill cap? The LIM bolts will sometimes let oil seep up through them which you can use threadlock to stop and it could be the valve cover gaskets, but that wouldn't explain the coolant. The LIM gaskets are just way to common of a problem so... have fun
  3. #3 Re: Oil leak!!!!!
    Apr 2009
    stockton ca
    lim for the win theres a write up with video on here for it its not that bad might aswell do the valve covers while its all apart
  4. #4 Re: Oil leak!!!!!
    Feb 2009
    decatur, al
    See I changed the gaskets about 10,000 ago. Would they have failed that quickly or could it have just taken that long to wear out a weak point?
  5. #5 Re: Oil leak!!!!!
    OKC
    Quote Originally Posted by musiknjoyr View Post
    They shouldn't have, but if you used the plastic ones (like I did b/c I didn't know about the aluminum ones yet ) then it's very possible. You could try to give it a thorough inspection, but if you don't see anything obvious it's gonna be the LIM.
  6. #6 Re: Oil leak!!!!!
    Feb 2009
    decatur, al
    plastic yes but aluminum ones? tell me more
  7. #7 Re: Oil leak!!!!!
    OKC
    Go to zzperformance.com and look under gaskets, they have the aluminum ones for around $55. I think some part stores have them. Its definintely the best way to go, I've been thinking about replacing mine with the aluminum ones and I just put in plastic ones
  8. #8 Re: Oil leak!!!!!
    Williamsport, PA.
    I'm new here but I just recently went through this, Dorman makes an aluminum updated gasket for these engines at a good price. Includes all and I mean all! gaskets neccesary(did I get that right neccesary) LOL any way,to do the job inc. LIM bolts. for the 3.1 or 3.4 engines the part # is 615-205 a good place to get this kit is www.ecaronlineusa.com besides the job is fun and educating if ur new to it. Hope everything works out 4 ya.
  1. odd leak... need some help
    By TLSheff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2010, 05:10 PM
  2. Bad oil leak
    By evilpacker in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-29-2009, 09:56 AM
  3. Oil Leak
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:45 PM
  4. s/c leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 06:30 PM
  5. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
