Thread: where to put oil psi sending unit???
Results 1 to 8 of 8
ERDGT1 where to put oil psi sending... 01-15-2010, 12:22 AM
whiney Re: where to put oil psi... 01-15-2010, 12:24 AM
97gtsc Re: where to put oil psi... 01-15-2010, 12:32 AM
TheOtherNick Re: where to put oil psi... 01-15-2010, 01:38 PM
ERDGT1 Re: where to put oil psi... 01-15-2010, 04:25 PM
TheOtherNick Re: where to put oil psi... 01-15-2010, 07:36 PM
copgtp Re: where to put oil psi... 01-16-2010, 12:19 AM
ERDGT1 Re: where to put oil psi... 02-01-2010, 09:30 PM
  1. #1 where to put oil psi sending unit???
    at the house
    Where would I install the sending unit for an aftermarket gauge?. I searched and found people putting it in the factory sending unit location but they don't comment on if that triggers anything in the ECM. As my 2004 NA GP does not have an oil gauge I assume the sending unit they are talking about is for the ECM to know the pressure only? I can't stand not having the normal 4 aux gauges.
    2004 Grand Prix GT1 - K&N aifilter, Hawk pads
    1988 5.7L IROC-Z - Alot of stuff that I am sure no one wants to hear about since this isn't the right forum.
  2. #2 Re: where to put oil psi sending unit???
    swift current,sask.
    What you could do if you want to keep the dummy light in the dash, is get a brass tee with 1/4 ends and hook your gauge into one and you sender into the other.
  3. #3 Re: where to put oil psi sending unit???
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    x2^^^
  4. #4 Re: where to put oil psi sending unit???
    Charles City, IA
    Just take the factory one out. It will not do anything.
    SMGPFC Two Nipple General
  5. #5 Re: where to put oil psi sending unit???
    at the house
    OK, thanks for both suggestions. I will figure out which one I will do when I dig in there.
  6. #6 Re: where to put oil psi sending unit???
    Charles City, IA
    The idiot light comes on at like 2psi by then your ****ed anyways. It is a normally open circuit so taking it out would be the same as having it in with oil pressure.
  7. #7 Re: where to put oil psi sending unit???
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I agree with 01gtp on this one. By the time the dummy light comes on the engine is toast anyways. Ditch the factory sending unit and put the aftermarket in it's place. Make sure you use some teflon tape on all the fittings and after you install let the engine idle and make sure you have no leaks at the sender.
    Good luck!
    For all your 3800 needs:
  8. #8 Re: where to put oil psi sending unit???
    at the house
    Great replies guys, thanks. I am going to do the gauge only and ditch the light. Just have to figure out what Autometer setup I want.
  1. What ther GM cars with same/ functional fuel sending/ pump units?
    By PCweber in forum General Tech Discussion
    Last Post: 08-21-2009, 03:55 PM
  2. fuel sending unit
    By stanggreg90 in forum General Tech Discussion
    Last Post: 08-01-2009, 06:23 PM
