I agree with 01gtp on this one. By the time the dummy light comes on the engine is toast anyways. Ditch the factory sending unit and put the aftermarket in it's place. Make sure you use some teflon tape on all the fittings and after you install let the engine idle and make sure you have no leaks at the sender.
Good luck!
