Thread: Heat Problem HELP!
Results 1 to 7 of 7
kassel98gt Heat Problem HELP! 02-16-2011, 10:28 AM
FordMan77 Re: Heat Problem HELP! 02-16-2011, 02:11 PM
BillBoost37 Re: Heat Problem HELP! 02-16-2011, 02:48 PM
kassel98gt Re: Heat Problem HELP! 02-16-2011, 11:06 PM
BillBoost37 Re: Heat Problem HELP! 02-17-2011, 07:35 AM
taman86 Re: Heat Problem HELP! 02-18-2011, 12:00 AM
klj5022 Re: Heat Problem HELP! 02-18-2011, 12:04 AM
  1. #1 Heat Problem HELP!
    SE Level Member kassel98gt's Avatar
    Howell,MI
    so ive looked around n havent found anything on my heater problem.
    i have a 98 gt and the heat hardly ever works any more and randomly will turn on every once in a great while. most times for short periods when i first start the car then just quits.
    not sure what to do about this so any help would b greatly appreciated.
    thx
  2. #2 Re: Heat Problem HELP!
    St. Louis
    So is it you are not getting air from the vents (ie- blower not turning on?), or blower works but no heat???
  3. #3 Re: Heat Problem HELP!
    Nick approved this message: "Put on a coat"
    Seriously though.. is the blower working, is the car not heating up.. there's some basic stuff we need to know to consider being able to help out.
  4. #4 Re: Heat Problem HELP!
    Howell,MI
    sorry the blower usually doesn't work then will randomly turn on with good heat once in a great while. mostly right after i start the car but sometimes will shut out after a few seconds or last the entire ride. but besides for the few times it works i always have to layer up 4 the winter
  5. #5 Re: Heat Problem HELP!
    Sounds like blower, blower resistor or ignition switch.
  6. #6 Re: Heat Problem HELP!
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    dont mean to thread jack here but mine kinda does the some thing but when i turn mine on my DIC cuts out, but when i turn the blower off the DIC comes back on.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  7. #7 Re: Heat Problem HELP!
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Kassel your blower is probably starting to go/ is gone but comes for a visit every once in a while and taman you sound like you have a fuse or electrical prob
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  1. Driver side- no heat, blending door problem?
    By suzuki1211 in forum General Tech Discussion
    Last Post: 02-02-2011, 09:32 PM
  2. problem #2.. #5 on heat control not working
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 12:13 PM
  3. Heat Problem
    By holmz in forum General Tech Discussion
    Last Post: 12-07-2009, 08:34 PM
  4. Heat/fans problem getting worse
    By Freebeer187 in forum General Tech Discussion
    Last Post: 01-11-2009, 06:38 PM
  5. Cabin heat question - Possible problem
    Last Post: 11-13-2008, 08:42 AM
