Thread: couple of quick questions about tstats
Results 1 to 19 of 19
  1. #1 Re: couple of quick questions about tstats
    Quote Originally Posted by NoTyme View Post
    OK Guys;
    Thanks for the info. I was a bit confused when I read about the screwdriver because there is no slot for a screwdriver on mine. It looks like 2 different size hex heads. I'll try the removing when cold method if the old fashion method don't work; I burped from the radiator cap itself...
    This.
    common for the bleeder valve to become clogged.
    MAKE SURE YOU DO BLEED IT PROPERLY.
    Then check it again after going for a nice 30 min drive while watching the temp gauge.
  2. #2 Re: couple of quick questions about tstats
    SE Level Member NoTyme's Avatar
    southeast Michigan
    I did drive down to a local car wash to spray off the section of engine where some of the anti-freeze leaked and I could see the temp gauge actually working. About 8 mile drive and I did function several times during the drive. It would slide up just over 180 and then slide down to about 165 or so... Just taking a good guess at the number... Lots of heat again...
    I apologize for high-jacking pontiacgp759's thread.
  1. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  2. Couple of questions..
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:38 PM
  3. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  4. couple of quick downpipe questions.
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 03-18-2009, 07:36 PM
  5. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
