Thread: SF Bay Area assistance (LIM leak diagnosis)
Results 1 to 4 of 4
  1. #1 SF Bay Area assistance (LIM leak diagnosis)
    SE Level Member Toxicologist's Avatar
    Albany, California
    I'm in El Cerrito and I have a pretty significant oil leak. I was wondering if someone with more experience with this motor can have a look and confirm that its the LIM gaskets as I suspect. And maybe I can borrow your garage for a Saturday? I don't really want to spend a whole day in the rain by the side of the road doing a gasket replacement. I know this is a long shot, but I figured I would ask. Thanks!
  2. #2 Re: SF Bay Area assistance (LIM leak diagnosis)
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    hopefully someone can help you out..if i was closer i would
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: SF Bay Area assistance (LIM leak diagnosis)
    Apr 2009
    stockton ca
    Hey man id help ya out but im in stockton Altho i do have a garage and tools
    Im about 1.5-2 hours away
    Its really not that bad of a fix if it is just the lim gaskets....
  4. #4 Re: SF Bay Area assistance (LIM leak diagnosis)
    Albany, California
    OK, so I figured I would go about this a different way. Here are some pictures of what things are looking like. I actually think the front valve cover gasket has failed also.
    Appears to be coolant where there shouldn't be as indicated by the oil fill cap with nasty yellow gunk when the motor is cold.
    There is also sludge in the valley between the intake manifold and both valve covers. It looks like the oil may actually be coming from the valve cover mostly but I couldn't get a good angle on that for a picture.
    1. I found a garage to use but have to rely on my own tools. I watched the video, and it doesn't look like any special tools are needed. I have a decent mechanics toolset (ratchets, wrenches, etc) and a torque wrench. Is there anything special I might need that I missed in the video?
    2. I'm obviously going to change the oil and coolant, but as there seems to have been some mixing of the two, should I do anything in particular to try to eliminate coolant from oil and oil from coolant?
    3. Other than LIM and UIM gaskets, coolant elbows and valve cover gaskets, should I consider replacing anything else at this point? I've heard that the plenum lasts about 100K before it warps and causes problems and it was replaced at 100K on the car and I'm now at 161K. Should I consider swapping that out? Also, I'm assuming spark plugs will be more accessible with things torn down, so maybe I'll do plugs and wires as well now. What's the suggestion on those for a stock GT?
    Thanks for the help!
  1. New to Forum, and need assistance on Horn???
    By Ninjaman in forum General Tech Discussion
    Last Post: 12-27-2009, 11:07 PM
  2. General Motors Roadside Assistance of Canada
    By l3enner in forum Off Topic Discussion
    Last Post: 05-27-2009, 08:57 PM
  3. Bushings Assistance Whereto buy?
    By Mjr Minor in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2008, 04:23 PM
  4. new projectors! need assistance:)
    By blowngt84 in forum General Tech Discussion
    Last Post: 08-28-2008, 08:38 PM
  5. 1999 automatic transxale diagnosis help
    By Budman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2008, 08:23 AM
