Thread: 2004 GrandPrix Fuel Pump
Results 1 to 9 of 9
  1. #1 2004 GrandPrix Fuel Pump
    michigan
    Is there excess to the fuel Pump in the trunk of the car or , will i have to remove the Fuel Tank?
  2. #2 Re: 2004 GrandPrix Fuel Pump
    GTX Level Member Deimos's Avatar
    iowa
    Trunk of car and cake to do.
  3. #3 Re: 2004 GrandPrix Fuel Pump
    I live here. UR LOSN's Avatar
    Rockford, IL
    Moved to correct section.
  4. #4 Re: 2004 GrandPrix Fuel Pump
    michigan
    Thanks guy for the location of the pump ,i installed the new pump and the car runs for 5 seconds and dies any repair tips for this.
  5. #5 Re: 2004 GrandPrix Fuel Pump
    michigan
    Thanks for the location of the pump .I installed another pump and car starts and runs for 5 seconds and dies with lots of fumes and smoke from exhaust. any repair tips for this problem. Thanks
  6. #6 Re: 2004 GrandPrix Fuel Pump
    michigan
    I changed out the pump with a used one ,pump pressure is 60psi key on in a few hours pressure drops to 3psi , car still won't run . any repair tips, thanks
  7. #7 Re: 2004 GrandPrix Fuel Pump
    Charles City, IA
    What do your plugs look like?
    SMGPFC Two Nipple General
  8. #8 Re: 2004 GrandPrix Fuel Pump
    MT
    Sounds more like a security system issue to me?
    But yeah, fuel pump may not have been the problem in the first place.
  9. #9 Re: 2004 GrandPrix Fuel Pump
    michigan
    I changed the plugs with champion not AC ,the car started after pumping the petal almost running the battery down.Their was lots of fumes and smoke from exhaust but this cleared. The car ran good until the next day , I tryed starting and it would not start again, the pressure had droped to 3psi before starting but at key on jumped up to 60psi. checked plugs ,all we're fouled out. I pulled fuel rail and checked injectors for leaking seems ok , checked MAP, MAF ok, checked for spark at plugs seems ok. Could it be a weak coil . Car still trys to start like its flooded lots of fumes also should their be 50psi on the fuel rail at all times?
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. fuel pump
    By acragon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 09:37 AM
  3. 1988 grandprix tranny to 1993 grandprix
    By avaitors in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 09-14-2009, 03:34 AM
  4. Fuel pump??
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:25 AM
