Thread: 1.9 modified rocker installation
Results 1 to 20 of 21
  1. #1 1.9 modified rocker installation
    GT Level Member rolyat's Avatar
    OKC
    Okay, so I am putting on the modified rockers from zzp on my gtp. I replaced the valve springs with L76/L92 springs and used the retainers from the L76/L92 engine as well. The rockers are not coming in contact with the rocker plate, all the pressure is on the pushrods and valve stems, prior to torquing them. Basically I don't know if that's how its suppose to be I thought when I unbolted the stock rockers they just sat down on the plate. I haven't torqued them down yet cause it seems like if I did it would keep the valves open. The springs are installed at 4.5cm(about 1.77") is that right? I don't know anything about the lifters on these cars, but are they designed to compress. If they are how could the rockers be torqued accurately? I feel like I need shims under the plates for it to be right. I don't know, this is my only form of transportation so I need to figure this out quick.
  2. #2 Re: 1.9 modified rocker installation
    Portland Oregon
    The lifters are hydraulic. They will compress
  3. #3 Re: 1.9 modified rocker installation
    Banned - Busted For Scamming
    Feb 2009
    You need to rotate each cylinder you are torquing to TDC to get an accurate torque.
  4. #4 Re: 1.9 modified rocker installation
    OKC
    I haven't torqued anything yet cause I don't know if the rockers should be contacting the pedistal before they are torqued. I thought I read somewhere that you didn't need to have the cylinder on TDC to torque it on this engine?
  5. #5 Re: 1.9 modified rocker installation
    OKC
    Does torquing the rockers set the preload on the lifters or something?
  6. #6 Re: 1.9 modified rocker installation
    Charles City, IA
    Mine sat right on the pedestal when I put them on. Make sure You have everything sitting right.
    SMGPFC Two Nipple General
  7. #7 Re: 1.9 modified rocker installation
    OKC
    Any ideas on what could cause it because everything looks right. Could it be the springs I used?
  8. #8 Re: 1.9 modified rocker installation
    in a house
    Quote Originally Posted by rolyat View Post
    Do you have the modified pedistals?
  9. #9 Re: 1.9 modified rocker installation
    OKC
    Quote Originally Posted by silverstreak View Post
    Yeah, but those just have a larger groove for the pushrod.
    I guess I'm just having a misunderstanding of how hydraulic lifters work. One rocker will be making slight contact with the pedistal while another one won't be close. So the pushrods are at different points. So what I'm getting is you can just torque them all down as it is and it will compress the lifter and torque the rocker, or you can put each cylinder on TDC and the rocker will make full contact with the pedistal so the torquing process will be more accurate. Is this right or am I way off?
    BTW I'm using reusable bolts not TTY.
  10. #10 Re: 1.9 modified rocker installation
    OKC
    I guess nobody knows, I'll just torque them all down and hope for the best....
  11. #11 Re: 1.9 modified rocker installation
    GT Level Member gpgt04's Avatar
    MA
    did you just torque them all down with out bringing each to tdc? i want to get these but dont know how to bring each cylinder to tdc
  12. #12 Re: 1.9 modified rocker installation
    OKC
    Yeah I did because I read a few things saying you didn't need it on tdc plus its not in zzp instructions. It will just compress the valve spring before the rocker is torqued all the way if you don't put it on tdc, I don't think that's a problem.
  13. #13 Re: 1.9 modified rocker installation
    DevilsOwn
    Guest
    Just torque them down, thats all ihave ever done.
  14. #14 Re: 1.9 modified rocker installation
    Charles City, IA
    Yeah you just torque them down.
  15. #15 Re: 1.9 modified rocker installation
    cant torque them down correclty with oil in the rocker bolt holes.
  16. #16 Re: 1.9 modified rocker installation
    Donating Users blowfishRus6's Avatar
    g.a.
    q tips are your friend.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  17. #17 Re: 1.9 modified rocker installation
    OKC
    Air compressor works pretty good too.
  18. #18 Re: 1.9 modified rocker installation
    Air compressor on rockers? What do you have the arms of a 5 year old? LOL
    The TQ. Spec is like 25ft. lbs. on reusable bolts and 11 on TTY's...I've done a few rocker installs and never turned the motor to TDC, only thing I do is unplug the ICM (bottom of the coil pack bracket) while the valve covers are off AFTER the rockers are installed and have someone crank the engine over and over to check to see if they all move properly and everything is aligned.
  19. #19 Re: 1.9 modified rocker installation
    no, for blowing oil out of the rocker bolt holes.
  20. #20 Re: 1.9 modified rocker installation
    OKC
    Haha, nah I could snap those bolts with a 1/4'' ratchet if I wanted. lol
  1. rollers or modified.
    Last Post: 08-19-2009, 04:26 PM
  2. My modified headlight!!
    By Malefic_GP in forum General Tech Discussion
    Last Post: 09-27-2008, 11:27 PM
  3. Modified '97 TB?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 10:57 PM
