Thread: HVAC Fan Speed Setting 5 will not work
Results 1 to 5 of 5
  1. #1 HVAC Fan Speed Setting 5 will not work
    Columbus
    Ok guys here's what I've got.
    Wifes 02 Grand Prix GT, fan speeds 1-4 didn't work, and speed 5 just stopped too, as I was coming home from getting the new resistor. So replaced the resistor anyways cause it obviously needed it (old one the PCB was cracked in half!). Now speeds 1-4 work fine, but no speed 5. Any idea what's up? I'm hoping it's not the ignition switch. I'm willing to be it is, but I'm holding out hope it's not.
    Thanks.
  2. #2 Re: HVAC Fan Speed Setting 5 will not work
    Banned - Busted For Scamming
    Feb 2009
    I believe that the high speed has a separate feed and fuse, you might want to check that. Im not 100 percent sure but maybe.
  3. #3 Re: HVAC Fan Speed Setting 5 will not work
    Columbus
    Ok thanks I'll go through the fuses after I pick up the wife from work. (She can't drive my car cause it's a manual HA!)
  4. #4 Re: HVAC Fan Speed Setting 5 will not work
    GT Level Member hourang's Avatar
    commerce, mi
    the switch could be bad
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  5. #5 Re: HVAC Fan Speed Setting 5 will not work
    PA
    Yes, the high speed has a separate fuse. So check that. But also could be a bad ignition switch.
    2001 GSE
  1. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  2. setting up new system
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 11:27 PM
  3. HVAC doesnt blow air any speed
    By GTX in forum General Tech Discussion
    Last Post: 01-01-2009, 01:11 AM
  4. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  5. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
