Thread: setting up new system
Results 1 to 6 of 6
  1. #1 setting up new system
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    So i want to power all 6 speakers that i replaced in my gp that were powered by the bose system? should i buy 2 amps to run all 6 speakers or run 4 speakers off the headunit and 2 from an amp? if i run all 6 speakers off 2 amps all my pre amp outputs are taken up and i was wondering how i would add a sub? Someone tell me which road will leave me the most satisfied
  2. #2 Re: setting up new system
    Jan 1970
    Maquoketa, Iowa
    I just ran 4 infinity's off a alpine headunit when I ditched the bose. You don't need 6 speakers, i don't know what size the extra 2 in the back were but they were small. Look in from the trunk at the back speakers and you should be able to see them.
  3. #3 Re: setting up new system
    Jan 1970
    Maquoketa, Iowa
    Where in iowa you from?
  4. #4 Re: setting up new system
    Jersey
    6 is overload, i remember i installed 6 infinity reference series speakers in my friends camaro ss and it was a bit much, but he loved it. You should do 2 components in the front with 3 way 6x9's in the rear with a 4 channel amp and call it a day.
    16' wrx sti- stock
  5. #5 Re: setting up new system
    the rears dont count as 2 speakers "technically", the one 4 inch is your highs and the 6x9 is your low pass bass, kinda like a componet set. there is no need to do that many speakers. Add some nice coax's or componets in the fronts, 6.5's if you want a lil more bass, then some nice 3 ways like the above stated and you you'll be just fine. Get a 4 channel and a mono, and a nice deck with 3 rca's with 4 volt preouts and you'll be good to go.
  6. #6 Re: setting up new system
    Nov 2008
    Iowa
    thanks for the input guys
  1. Complaint With One Of This Forums Setting
    By Street Wolf in forum Forum Bugs/Suggestions
    Last Post: 12-22-2008, 01:29 PM
  2. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  3. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  4. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  5. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
