Thread: wipers that won't park
Results 1 to 14 of 14
  1. #1 wipers that won't park
    Somerset, Ky
    On my 2001, the wipers started to not park all the way down. They stick up about 6 inches. I can hear the wiper motor running trying to park them. If i push on them, they go right down with no resistance. I read in here about a metal tab that gets bent from snow and ice and you have to bend it back. Can anyone tell me where this tab is? Thanks and Happy New Year to all
  2. #2 Re: wipers that won't park
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    take socket to the nut on the arm. Loosen up and then sit arm down to where it is suppose to rest. Tighten back down but not too tight. Repeat for other side.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: wipers that won't park
    Topeka, KS
    I used to have a picture of the metal tab. Seems like this happens to me about 3 times each winter. PM me if you need help fixing it.
  4. #4 Re: wipers that won't park
    Somerset, Ky
    Thanks a lot, but I saw a drawing in here that shows it.
  5. #5 Re: wipers that won't park
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    If they are only sitting about 6" above the "parked" position, I doubt the tabs are your problem. When the tabs go bad the wipers actually park in the up position.
    I agree with Toofastgs on this one.
    For all your 3800 needs:
  6. #6 Re: wipers that won't park
    Guam
    Quote Originally Posted by Toofastgs View Post
    ! Why would you suggest this! There is an issue that needs to be fixed...
  7. #7 Re: wipers that won't park
    When you pull the cowl, you will be able to see if the tab is being caught by the arm and then the trans mechanism on top reverses itself to park the wipers. If the arm isn't catching the tab, the tab is likely bent outward and needs a tweak.
    If the mechanism on top doesn't reverse when the tab is caught by the arm, then that mechanism can be replaced. (LMK I have a spare).
    Lastly..if you have checked all this and it appears that nothing will cure the issue, the wiper motor does have a delay/pulse box (electronic) mounted to it. Easiest thing to do here is replace the motor/box assembly. This was the fix when my wipers parked at the top. No arm adjustment or mechanism swap helped. Overall it's a pretty easy and quick fix. If you get one from a JY, try to find a Regal/GP/Century that had a plastic cover added over the motor. It's there to keep ice and water from building up on the mechanism and causing the trouble.
  8. #8 Re: wipers that won't park
    Somerset, Ky
    Thanks Bill. I'm sure the tab is bent as it started doing this right after we had snow and the car sits outside. I can here the motor running trying to park them but it doesn't catch the tab. I will fix this if it ever warms up here.
  9. #9 Re: wipers that won't park
    Wausau, WI
  10. #10 Re: wipers that won't park
    Largo, Florida, United States
    the russian way always fixes it!
  11. #11 Re: wipers that won't park
    Topeka, KS
    I got a quick question then... What causes the wipers to pause mid stroke when in the intermittent mode ? My wipers park correctly and function normally in the low and high mode. They just have issues in the intermittent modes.
  12. #12 Re: wipers that won't park
    Wausau, WI
    Quote Originally Posted by rynoman03 View Post
    not sure..even when my tab was bent it parked in the down position when in intermittent mode.
  13. #13 Re: wipers that won't park
    Somerset, Ky
    It finally warmed up around here so I pulled the wipers and the cowl off. Looks to me like the tab has departed. My wipers go almost all the way down, when parked, and a little push on them when I get out of the car, puts them all the way back down. This car is just a winter beater so I decided to leave them alone.
  14. #14 Re: wipers that won't park
    Kansas
    my wipers stuck in the "up" position during the last snow/ice. When I took it all apart...tab was where it was supposed to be...<frustration>...took armatures and motor assembly out, sprayed brake cleaner to remove old dirt/slime/grease, reapplied lithium grease, reassembled...TADA! works wonderfully...time will tell how long.
  1. wipers staying up
    By Jakegday in forum General Tech Discussion
    Last Post: 12-15-2009, 03:35 PM
  2. help!!!! wipers adjustment plus couple others
    By bowhunter in forum General Tech Discussion
    Last Post: 03-25-2009, 04:36 PM
  3. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  4. Wipers on, Scan gauge out ???
    By RichCresci in forum General Tech Discussion
    Last Post: 11-16-2008, 10:37 AM
  5. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
