Thread: Projector HID
Results 1 to 20 of 43
  1. #1 Re: Projector HID
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Snip off the connectors on the blue and black wires going to thru the rubber plug. Pull those wires thru the plug. Now, on the harness (9007 plug) that came with the projector, you have a red and black wire setup, that goes to your 9005 high beam bulb...
    Now you have 2 other wires coming from that 9007 plug a blue and black wire, with female spade connectors. You have the other set of wires (blue/black) that you just removed from the rubber plug, connect the blue to the blue and black to black... (I'd just remove the female spade connectors and just tie them together or the time being and covered with electrical tape)
    The connector at the then end of the blue/black wire gets plugged into ballast...
  2. #2 Re: Projector HID
    Norristown, PA
    Quote Originally Posted by BlownBigBlock View Post
    that was incredibly confusing to me. Thats why i think i may need pictures if i want to get them in.
  1. I need projector help
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-30-2011, 07:47 AM
  2. Projector Question??????
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 08-13-2009, 09:56 PM
  3. projector headlights
    By musiknjoyr in forum Visual/Body Modifications
    Last Post: 03-01-2009, 04:08 PM
  4. projector headlights
    By 3800SE in forum Visual/Body Modifications
    Last Post: 10-15-2008, 07:57 AM
