Thread: Any one do this? DIY o2 emulator?
Results 1 to 9 of 9
  1. #1 Any one do this? DIY o2 emulator?
    SE Level Member abuckley1290's Avatar
    Jul 2008
    I was looking around and found this. I plan on removing my cat/u bend and replacing it with a glasspack and placing the o2 bung with this DIY emulator. Think it would work?
    Here is the link...
    http://forums.bimmerforums.com/forum...d.php?t=525568
    40th Anniversary GP
  2. #2 Re: Any one do this? DIY o2 emulator?
    Apr 2009
    stockton ca
    it could work since its just checks cat efficientcy by raising the o2 sensor out of direct exhaust flow it would read way less of the exhaust
  3. #3 Re: Any one do this? DIY o2 emulator?
    the subbie guys do it all the time. they just put a spacer in so it can read less of the gases flying by it and wont throw a cat code.
  4. #4 Re: Any one do this? DIY o2 emulator?
    Jul 2008
    so this would be a good solution to buying the emulator and still not mess with my fuel trims?
    40th Anniversary GP
  5. #5 Re: Any one do this? DIY o2 emulator?
    Jul 2008
    Well im doing it in a few hours..ill try to get some pics up
    40th Anniversary GP
  6. #6 Re: Any one do this? DIY o2 emulator?
    Aug 2008
    KCMO
    let me know how it works
  7. #7 Re: Any one do this? DIY o2 emulator?
    fuel trims? what? the rear o2 sensor has nothing to do with fuel trims.
  8. #8 Re: Any one do this? DIY o2 emulator?
    Apr 2009
    stockton ca
    the rear o2 sensor is only there to make sure the cat is working properly no other reason your fuel trims will be unaltered
  9. #9 Re: Any one do this? DIY o2 emulator?
    Donating Users chico's Avatar
    There is another home spun O2 eliminator ,the cost is around $2 ,U need a 100K resitor available at radio shack for instructions go to OQCGP I have been using this since 04 without a problem.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  1. O2 Emulator/ Simulator Emissions question
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 11:12 PM
