Thread: Cruise Control problem.
Results 1 to 3 of 3
  1. #1 Re: Cruise Control problem.
    GTX Level Member cerick08GP's Avatar
    Well, I’m happy to tell you your problem might be easily fixed.
    #1 Check your brake fluid level, if it is low add fluid.
    #2 Check to see if your 3rd brake light is working, if not replace the bulb. This also applies to any exterior LEDs you might have installed, if you have go back bulbs or add load resistors.
    If you do both of these IMHO you will have a 98% chance of getting your cruise control back. Also, if your brake fluid is low plan on replacing your front brake pads soon.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  2. #2 Re: Cruise Control problem.
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    I know I'm resurrecting an old thread but, I had to replace my abs module to get my cruise working again. I also had the infamous no TCS and ABS light. All of it was cured with the new module.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  1. Cruise control
    By betsgtp in forum General Tech Discussion
    Last Post: 11-27-2010, 10:12 PM
  2. Kr with cruise control on?
    By shanester in forum General Tech Discussion
    Last Post: 07-22-2009, 12:34 PM
  3. Cruise Control
    By ohioGTP in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2009, 11:39 AM
  4. Is this what you buy to fix cruise control?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 05-16-2009, 12:08 PM
  5. cruise control
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 02-01-2009, 12:18 PM
