Thread: So I found out why my rear window wasnt rolling down...
Results 1 to 16 of 16
  1. #1 Re: So I found out why my rear window wasnt rolling down...
    Waukesha, WI
    hahah i wish you luck on rewinding and it working properly
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: So I found out why my rear window wasnt rolling down...
    St. Louis
    I have! I actually did it twice to my drivers side front window. The first time it broke the plastic that hold one end of the cable, so I drilled a new hole and remounted the cable. Worked fine. I think the 2nd time was when I was removing the bad motor. When it broke again I finally just bought a new reg/motor assembly and lubed the sh*t out of the guides. No problems so far.
    And yes, it was time consuming and a PITA. I don't recommend it unless you are very determined and have time to kill.
  3. #3 Re: So I found out why my rear window wasnt rolling down...
    Jun 2011
    Douglasville, GA
    It looks like a PITA and i am not sure how determined I am... I am cheap though and don't have a couple hundred bucks to drop for a whole new assembly.
    There are tracks on the wheel ... do I need to be ultra worried about keeping the cable in the tracks?
  4. #4 Re: So I found out why my rear window wasnt rolling down...
    St. Louis
    Quote Originally Posted by skernan View Post
    Yes. You need to keep the cables in the tracks or it will either not go back together or will bind once assembled.
  1. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
  2. Rear Window Decals (OPINION)
    By Thunderturd in forum General Tech Discussion
    Last Post: 09-30-2009, 07:05 PM
  3. Rolling Your Rear Fenders Option #1 [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:52 PM
  4. Rolling Rear Fenders Option #2 [*]
    By VinnieGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:51 PM
