Thread: L67 to L32 swap
Results 1 to 12 of 12
  1. #1 L67 to L32 swap
    WI
    I was wondering what I would need to properly swap and L67 to L32 in 2000 GTP.
  2. #2 Re: L67 to L32 swap
  3. #3 Re: L67 to L32 swap
    Topeka, KS
    Maybe he wants a higher compression motor???
  4. #4 Re: L67 to L32 swap
    Quote Originally Posted by rynoman03 View Post
    L32 is not higher compression. it has coated pistons and rods and a genV blower.
    Quote Originally Posted by rocafella2032 View Post
    better blower? lower miles?
    you can buy the blower seperate. and since when has mileage been the culprit of motors going down? i have yet to see it.
  5. #5 Re: L67 to L32 swap
    WI
    A rod bearing went out in the engine and was looking to see if the upgrade would be feasible or not. I would like to upgrade to the L32 if I can find one cheap enough. Would be nice to have series III in a 2000.
  6. #6 Re: L67 to L32 swap
    Norristown, PA
  7. #7 Re: L67 to L32 swap
    May 2008
    staten island,NY
    L32 is the revised L67 kinda how galvatron was the better version of megatron, compression is the same
  8. #8 Re: L67 to L32 swap
    yeah, you can pretty much bolt it in and go. the blower youll have to do a minimal amount of work to make it work correctly.
  9. #9 Re: L67 to L32 swap
    WI
    I was reading that you have to replace the throttle body for it to bolt up because it's fly by wire and also a new ECM. Are there any kits that make this easier?
  10. #10 Re: L67 to L32 swap
    need a genV to genIII throttle body adapter. thats about it.
  11. #11 Re: L67 to L32 swap
    WI
    Where can a person find that? What about the blower, what has to be modified on that?
  12. #12 Re: L67 to L32 swap
    the vacuum setup i think is a little different or you have to cap something off. i dont remember.
  1. L36 swap to a L26 ????
    By BILLJR71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2010, 09:49 PM
  2. Top Swap
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 11:56 PM
  3. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-02-2009, 05:32 AM
  4. Almost done with top swap, but in serious need of help
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2009, 01:26 PM
