Thread: car wont pass emissions. obdii says not ready
Results 1 to 18 of 18
  1. #1 car wont pass emissions. obdii says not ready
    GT Level Member Joe m's Avatar
    mesa,az
    ok so i put a new battery in my car today and drove to the emissions to get it done. and it failed cuz the obdii was not ready. so i drove it around all day and after driving 85 miles and even 60 miles on the freeway i also turned off the car and let set for a couple min then drove again and its still saying not ready. is there a drive sequence i need to do to get the comp to load the settings? or how long and how much do i need to drive to get it working to pass?
  2. #2 Re: car wont pass emissions. obdii says not ready
    Banned
    Washington
    move to a better state
  3. #3 Re: car wont pass emissions. obdii says not ready
    mesa,az
    lol, i like arizona pretty easy emissions here, just have to do a obdii check and a gas cap if its 96+
  4. #4 Re: car wont pass emissions. obdii says not ready
    mesa,az
    nevermind i luckly found a drive cycle on the site so i guess ill go spend my day tomorrow trying to find a road to drive 55 for 5 min and slow to 20 without hitting breaks haha
  5. #5 Re: car wont pass emissions. obdii says not ready
    Apr 2009
    stockton ca
    Quote Originally Posted by Joe m View Post
    Freeway and off ramps and downshift
  6. #6 Re: car wont pass emissions. obdii says not ready
    Charles City, IA
    I like Iowas lack of emissions.
    SMGPFC Two Nipple General
  7. #7 Re: car wont pass emissions. obdii says not ready
    mesa,az
    yea that would be nice. since i dont know of a road there i can go 55 for 5 mins then coast to 20 while not hitting the brakes. can i put the front end of the car on stands and do the cycle with the wheels off the ground lol. or does the motor have to have load on it?
  8. #8 Re: car wont pass emissions. obdii says not ready
    Donating Users blowfishRus6's Avatar
    g.a.
    thats the drive cycle????? usally it just needs a 100 or so miles on it after the computer was reset. just drive it around alot...
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #9 Re: car wont pass emissions. obdii says not ready
    mesa,az
    well i already put 97 miles on the car since the new battery. and im limited to how far i can go really cuz i have a 3day temp tag lol
  10. #10 Re: car wont pass emissions. obdii says not ready
    Jul 2008
    sumter,south carolina
    wow... south carolina stopped doing emissions testing in the early 90's
    02 GTP with mods 05 GP for DD
  11. #11 Re: car wont pass emissions. obdii says not ready
    Apr 2009
    stockton ca
    At least your not in cali emissions out here is way strict
  12. #12 Re: car wont pass emissions. obdii says not ready
    mesa,az
    alright so i went to vato zone and checker and had thm both scan my obdii cuz i dont trust auto zone. but autozone pulled a P0141 HO2S Heater Performance Bank 1 Sensor 2, and i do belive checker pulled a P0144 HO2S Circuit High Voltage Bank 1 Sensor 3. should i go ahead and pay the 140 dollars for both parts to fix them or do i try to clear them and see if they come back?
  13. #13 Re: car wont pass emissions. obdii says not ready
    g.a.
    your pcm was just reset if it would not pass emision for readyness. readyness means that the pcm was just reset and it has not had long enough (milage wise) to adjust back in.
    if its showing codes, then you are probably past the readyness stage. but since the computer was reset (hence why it was in readyness mode) then if you just reset the codes, there just gonna come back.
    its slow.
  14. #14 Re: car wont pass emissions. obdii says not ready
    mesa,az
    alright. i didnt even know the odes were there cuz the car isnt throwing a check light. but i had a hunch and had them scan it anyway and thats what showed. so i dunno if i want to spend 150 bucks right now
  15. #15 Re: car wont pass emissions. obdii says not ready
    Apr 2009
    stockton ca
    Check them before you repair them the o2 sensor iss the most over replaced sensor on cars They maynot be faulty
  16. #16 Re: car wont pass emissions. obdii says not ready
    g.a.
    you could maybe pull them out and scuff them up with sandpaper or something to try and clean them up some. maybe just dirty and not reading properly.
    its slow.
  17. #17 Re: car wont pass emissions. obdii says not ready
    Feb 2008
    Blow-torch + carb spray + O2 sensor = old school way to try and re-vitalize on O2 sensor.
  18. #18 Re: car wont pass emissions. obdii says not ready
    g.a.
    sweet, nice to know
    its slow.
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
  3. OBDII code reader still lights up yellow..?
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 03-23-2009, 08:14 PM
  4. emissions
    Last Post: 02-22-2009, 11:56 PM
