Thread: L67 to L32 swap
Results 1 to 12 of 12
  1. #1 L67 to L32 swap
    WI
    I was wondering what I would need to properly swap and L67 to L32 in 2000 GTP.
  2. #2 Re: L67 to L32 swap
  3. #3 Re: L67 to L32 swap
    Topeka, KS
    Maybe he wants a higher compression motor???
  4. #4 Re: L67 to L32 swap
    Norristown, PA
    better blower? lower miles?
  5. #5 Re: L67 to L32 swap
    May 2008
    staten island,NY
    L32 is the revised L67 kinda how galvatron was the better version of megatron, compression is the same
  6. #6 Re: L67 to L32 swap
    Quote Originally Posted by rynoman03 View Post
    L32 is not higher compression. it has coated pistons and rods and a genV blower.
    Quote Originally Posted by rocafella2032 View Post
    you can buy the blower seperate. and since when has mileage been the culprit of motors going down? i have yet to see it.
  7. #7 Re: L67 to L32 swap
    WI
    A rod bearing went out in the engine and was looking to see if the upgrade would be feasible or not. I would like to upgrade to the L32 if I can find one cheap enough. Would be nice to have series III in a 2000.
  8. #8 Re: L67 to L32 swap
    yeah, you can pretty much bolt it in and go. the blower youll have to do a minimal amount of work to make it work correctly.
  9. #9 Re: L67 to L32 swap
    WI
    I was reading that you have to replace the throttle body for it to bolt up because it's fly by wire and also a new ECM. Are there any kits that make this easier?
  10. #10 Re: L67 to L32 swap
    need a genV to genIII throttle body adapter. thats about it.
  11. #11 Re: L67 to L32 swap
    WI
    Where can a person find that? What about the blower, what has to be modified on that?
  12. #12 Re: L67 to L32 swap
    the vacuum setup i think is a little different or you have to cap something off. i dont remember.
  1. L36 swap to a L26 ????
    By BILLJR71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2010, 09:49 PM
  2. Top Swap
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 11:56 PM
  3. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-02-2009, 05:32 AM
  4. Almost done with top swap, but in serious need of help
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2009, 01:26 PM
