so i disconnected and reconnected everything, inspected and cleaned the battery connections and the pcm connections, even tho the pcm was perfectly fine, and it threw the code at me again. i could be interpreting the description of the code wrong, but if the battery voltage is low, would that cause it to throw this code at me? other then that the only other solution i can see would be to replace the PCM(specially since the old pcm didnt do it) even tho i just got this one from Will!!! dammit!! as far as the hids, i guess it doesnt have anything to do with that, cuz i didnt even have to turn the lights on or the engine for it to throw the code at me again. i'm open to any solutions/suggestions
