You could replace the diode with one from a wrecked gtp with the auto climate controll. I did this by disassembling the climate controll sensor dome, prying the wire connector apart. The pins on the photo sensor are longer so I drilled out the hole for the photosensor to sit higher in the HUD module and soldered the photosensor from the top and bottom of the circuitboard.
