Thread: Looking at a 97 3.8l v6
Results 1 to 19 of 19
  1. #1 Looking at a 97 3.8l v6
    racine
    Need to know what to look for and if there are any problems. Its a 4 door 3.6L V6 and I'm getting it for 1100$ Interior and exterior look good and so do maintenance records, but I wanted to hear from you guys on if theres anything specific. Mileage is at 161,000 -- "alot I know, and I don't know what typical mileage is on these engines?"
  2. #2 Re: Looking at a 97 3.8l v6
    GXP Level Member
    Theworld
    161k is pretty high for any normal motor.
    What kind of car is it?
  3. #3 Re: Looking at a 97 3.8l v6
    racine
    Its a 1997 Grand Prix 3.8L V6 4 door. I need something thatll get me through for awhile and 1100 is cheap.
  4. #4 Re: Looking at a 97 3.8l v6
    Wooster, Ohio
    check the rockers for rust, check underneath above the exhaust for rust. Look for wet spots on the engine, mainly underneath on the oil pan and under the valve covers where the exhaust comes out of the engine. That spot is known and recalled for fires. Also its a good idea to have the front end checked out at a shop before you buy it. Most will do it free of charge or for about twenty bucks for a rack fee. These cars go through wheel bearings and that way they can check that, look at the underside better and see what your brakes look like. Even if it costs a few bucks to have it looked over by a mechanic it could save you your 1100 if this thing is a turd and needs 1100 in parts.
  5. #5 Re: Looking at a 97 3.8l v6
    racine
    Alright, it had service records which made me feel a bit more confident about it, I'll have to see it in person. The only rust he said was on the side below the doors, supposedly a problem on grand prixs.
  6. #6 Re: Looking at a 97 3.8l v6
    racine
    Are the bearings a pain in the ass to change on these cars? I know on my VW I had to have a shop press them and go through a bunch of crap to do em.
  7. #7 Re: Looking at a 97 3.8l v6
    Jul 2008
    sumter,south carolina
    they are easy as sh*t... 30 min job
    02 GTP with mods 05 GP for DD
  8. #8 Re: Looking at a 97 3.8l v6
    racine
    Nice, I would love to have a car that I can work on myself over something I have to take in. The VW was a nightmare, put almost 1400 in new brakes and wires hoses plugs coils etc and it went out on me 4 days later, engine seized.
  9. #9 Re: Looking at a 97 3.8l v6
    Wooster, Ohio
    thats a VW for ya, parts for these cars are cheap and easy to find. The wheel bearings do run about 100 per side for the good ones though
  10. #10 Re: Looking at a 97 3.8l v6
    racine
    cheaper than oem vw bearings, i replaced two on that car.. i saw theres a recall that started in may for the exhaust manifold recently for the car, i should probably see if thats been done or not yet as well.
  11. #11 Re: Looking at a 97 3.8l v6
    Jul 2008
    Quote Originally Posted by Pittman06 View Post
    i priced timkens for i THINK 140 bucks each, i jus did my driver side with a cheaper aftermarket bearing for 58 bucks shipped. either way they are cheap and easy to fix i also had a 97 GT back in the day... i doggeddddddddd that thing out and it lasted to me around 200k miles when i sold it... only major thing i had to replace was a transmission one time..
  12. #12 Re: Looking at a 97 3.8l v6
    Jersey
    beware, those 97 gt's have a weak trans.
    16' wrx sti- stock
  13. #13 Re: Looking at a 97 3.8l v6
    vacuum powered trans FTL
  14. #14 Re: Looking at a 97 3.8l v6
    racine
    yeah, trans shifts right away fine, and i haven't run into any problems. guess i cant complain for 1000$.. the only thing i noticed was a noise when i brake hard and traction control takes over. oh well its just an in betweener.
  15. #15 Re: Looking at a 97 3.8l v6
    SE Level Member 97GT's Avatar
    Nov 2009
    NY
    hey I have a 97 GT(3.8) w/ a swapped engine but I have the original transmission @206K miles, I have heard from many people saying the transmission is crap, but thats not the case in my book(smoooth shifting, NO complaionts). Obivously there are little things that come w/ age that I have issues w/ (paint,interior headliner coming apart at the tip where the sun visors are, dash is starting to separate by the cluster, window motors, etc...) And I have to agree w/ kawaford thats alot of miles for a original engine(I swapped my original engine @160K doing 80mph and blew my head gasket ended up cracking the piston) so beware on the engine... I do MOST of my own work on the car(oil change,brakes, belts, etc...)and for the most part its a VERY low maintance car. Good Luck, and I hope this helps
  16. #16 Re: Looking at a 97 3.8l v6
    Mn
    Im picking up a 97 SE w/3.8 for $500 .... Had a mechanic look it over and said that he never seen a car more cleaner... well except the rust under the doors... I have plans for that.
    I know they flushed the radiator every other year... the trans was done last summer (flushed) and replaced alot of stuff at the same time ($2300 worth of misc stuff since they were going on a trip... they wanted to make sure nothing would go wrong... I think the dealership took advantage of them though) Heck I get 2 free oil changes with it also
  17. #17 Re: Looking at a 97 3.8l v6
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    Quote Originally Posted by brook011 View Post
    that your ABS, it makes a funny sound. get new pads, or bigger brakes
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  18. #18 Re: Looking at a 97 3.8l v6
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    theres a cheap easy front brake upgrade for these cars, hit the "search" buttton. good luck!
  19. #19 Re: Looking at a 97 3.8l v6
    Guam
    Quote Originally Posted by KawaFord View Post
    161K on a 1997 is normal yearly driving mileage...
    As long as it was taken care of, it should go for 200k easily!
    Things to look for:
    Inspect the oil, trans and coolant levels.
    Start it cold and hot, observe how it runs.
    Inspect around the intake manifold. Or have someone do it.
    Other then that, check all the basicis, any warning lights on and all electrical.
38l
