Thread: Is time for small claims court?
Results 1 to 5 of 5
  1. #1 Is time for small claims court?
    Aug 2008
    Seattle, WA.
    Quote Originally Posted by grand prix newb View Post
    Sh%t
    I ran car for 5 - 10 min to get it to operating temperture,
    Did compression test 3x on each cylinder and here are the results
    #1: 155 -150 - 150psi
    #2: 150 - 150 - 150psi
    #3: 80 - 80 - 80psi (sh@t-f%ck)
    #4: 160 - 160 - 160psi
    #5: 170 - 170 - 170psi
    #6: 180 - 175 - 175psi
    Looks like hg or head right?
    Yeah. Maybe when you take it apart you might even find a chipped piston.
    Quote Originally Posted by JoelW98GTP View Post
    Sounds like hg or piston. Cost me $1056 for two new hgs, uim gasket, lim gasket, head studs, em gaskets, vc gaskets, coolant flush, water pump, thermostat, plugs, and wires. Of course, that was paying a shop to do it of course. You could do a coolant system leakdown test to try and cancel out a bad piston and/or verify its just the hg.
    Posted earlier
    Thanks bud,
    I got the scaneer, and it read as follows:
    1 of 2 -
    code P0303, and undernieth code it says Cyldinder #3 Misfire
    2 of 2- (Same)
    code P0303, and undernieth code it says Cyldinder #3 Misfire,
    Why did it say the same code twice? Is it because of two different problems that caused the P0303 Code
    Thanks
    Quote Originally Posted by ASCStinger View Post
    the first is a pending code, second is a code currently set in the computer (AKA there has been a misfire problem in the past and it is also currently misfiring
    I wonder If I can sue the b***h for 2000 half of what I bought the 97 grand prix for.
    She must of known there was a misfire due to a bad head gasket or something, cause when I got the scanner that was the first time ses light came on, since I bought the car for 4000.
    1997 Grand Prix SE 3800 series 2
    No mods yet.
  2. #2 Re: Is time for small claims court?
    Wooster, Ohio
    unless you can prove that there had been previous codes stored in that car with that same cyl 3 misfire, and that they knew and cleared it intentionally, and that they knew there was internal damage and 100% mislead you to thinking there was nothing wrong with this car and the previous owner is a master mechanic and has been through the engine and its perfect with no issues at all or any trouble codes of any kind....your wasting your time. Basically it would come down to a battle of if they knew before, and if the car ran fine with no knocks or intentional coverups (ie 15w40 oil in it) then it will go no where fast. Thats a very fine subject that normally favors the seller no matter what. Your best bet is to pick up a used L36 for 400 to 600 and chock up your pride, and mod in the process. My sis is a Paralegal and i've been through this same thing in the past man...and i'm sorry
  3. #3 Re: Is time for small claims court?
    Aug 2008
    Seattle, WA.
    Quote Originally Posted by Pittman06 View Post
    Thanks man, your the second person to advise me to get another used engine, so I think thats what I will do. And thanks for the legal advice also.
    No mods yet.
  4. #4 Re: Is time for small claims court?
    Wooster, Ohio
    it sucks but you have to prove so much its just not worth it. Check out http://www.car-part.com, it searches junkyards all over the country or local in your area and compares pricing, its freakin awesome! Also i know the member Kfish just became a vendor and gets ahold of a lot of used parts with good pricing, so send him a pm and he can probably help you track a deal down.
  5. #5 Re: Is time for small claims court?
    Aug 2008
    Seattle, WA.
    Thanks for the link bro, I heard of that before from a diferent site but I had forgotten the name of it. and I will pm kfish down the road.
    Mario
    No mods yet.
  1. I need court advice
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 12-17-2009, 11:02 AM
  2. Small world!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 08-29-2009, 07:08 AM
  3. New small appearance mod..
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 03-31-2009, 11:49 PM
  4. Went to court yesterday
    By stkks in forum Off Topic Discussion
    Last Post: 01-08-2009, 04:28 PM
  5. An interesting approach to insurance claims
    Last Post: 08-06-2008, 10:05 AM
