Thread: Coolant spray/leak. Quick fix just 1 question
Results 1 to 10 of 10
  1. #1 Coolant spray/leak. Quick fix just 1 question
    GT Level Member VejGTP's Avatar
    USA
    This is for a 2004 GP GTP. Lately I've been smelling antifreeze while I'm driving, I looked under the hood and there is antifreeze sprayed all over pretty much everything on the left side.
    I just had a closer look today and I found out that the small tube with coolant running through it was touching the supercharger belt and it was cut open. The place I bought the car from replaced the battery right before I drove off with it so they must have moved the tube over and not put it back in place. (It is zip tied to something)
    I'm just wondering if anyone knows what this small tube is called so I can replace it. Here are a few pictures!
    If anyone can help I'd really appreciate it!!
  2. #2 Re: Coolant spray/leak. Quick fix just 1 question
    Charles City, IA
    Just go to a parts store with the hose and get some hose the same size. It is supposed to clip into your fuse panel. I just zip tired mine up to the fender brace.
    SMGPFC Two Nipple General
  3. #3 Re: Coolant spray/leak. Quick fix just 1 question
    USA
    Do I need to wait a certain amount of time after turning the car off before I remove it?
  4. #4 Re: Coolant spray/leak. Quick fix just 1 question
    as long as its coolish and theres no fluid in it. aka, the rad cap isn't pushing fluid into it.
  5. #5 Re: Coolant spray/leak. Quick fix just 1 question
    Charles City, IA
    Better done with the car cool. Unless you slowly open the rad cap.
  6. #6 Re: Coolant spray/leak. Quick fix just 1 question
    Its attached to the rad cap on the new ones?
  7. #7 Re: Coolant spray/leak. Quick fix just 1 question
    Charles City, IA
    no but you have to remove the cap to fill the rad which is probably low.
  8. #8 Re: Coolant spray/leak. Quick fix just 1 question
    USA
    It's been in the garage all day and it's freezing outsize so the car isn't warmed up at all. I started it like 15 minutes ago but only for about 5 minutes.
  9. #9 Re: Coolant spray/leak. Quick fix just 1 question
    Charles City, IA
    It would be fine then. Go for it.
  10. #10 Re: Coolant spray/leak. Quick fix just 1 question
    USA
    Thanks for the help . Got it fixed. Just bought some new hose and used those metal screw clamps to keep it on!
  1. Coolant Leak..help
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 10:56 PM
  2. coolant leak
    By cheesewhiz in forum General Tech Discussion
    Last Post: 10-22-2009, 01:11 PM
  3. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  4. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  5. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
