Thread: New to Forum, and need assistance on Horn???
Results 1 to 9 of 9
  1. #1 Re: New to Forum, and need assistance on Horn???
    Wooster, Ohio
    if you check your relay and put power through the terminal to power the horn will it work? Also if you hit the horn switch to you have signal coming to your relay...that will tell you which side you need to check into basically. Btw welcome to the forum!
  2. #2 Re: New to Forum, and need assistance on Horn???
    Tennessee
    Pulled the relay and made a small jumper wire to run from positive post of the battery to the female terminal that fires the horn. The horn works everytime you touch the wire to the positive post. So this tells me all the wiring from the fuse box to the horns is ok. I am still confused as to why the relay is not energizing. By the BCM, or the horn switch, something fishy is going on.I even pulled the dash apart to look for any loose connectors, or anything that looked out of the ordinary. No luck.........
  1. General Motors Roadside Assistance of Canada
    By l3enner in forum Off Topic Discussion
    Last Post: 05-27-2009, 08:57 PM
  2. Horn Help
    By PhilsGTX in forum General Tech Discussion
    Last Post: 03-07-2009, 10:03 PM
  3. Horn Going off
    By Bruteforce72 in forum General Tech Discussion
    Last Post: 01-12-2009, 01:47 PM
  4. Bushings Assistance Whereto buy?
    By Mjr Minor in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2008, 04:23 PM
  5. new projectors! need assistance:)
    By blowngt84 in forum General Tech Discussion
    Last Post: 08-28-2008, 08:38 PM
