Thread: Wiper arm not moving?
Results 1 to 3 of 3
  1. #1 Re: Wiper arm not moving?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    the nut that holds the arm on the gears (post) is most likely loose. not all that uncommon.
    the only reason you'd have to tear the dash apart is if your switch was bad. everything thing else windshield wiper related gets taken care of from under the hood
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: Wiper arm not moving?
    PA
    Yeah, all the controls are under the cowl under the hood. Take the cowl off and see if the nut is loose or the arm is stripped. Pretty straight forward to tell what is going on when you get under there.
    2001 GSE
  1. Moving from a 97 to 04?
    By Infinity9999 in forum 04+ Specifics
    Last Post: 07-28-2009, 09:33 PM
  2. happens only when im not moving
    By TheGreatSamG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2009, 12:02 AM
  3. Well... I might be moving on...
    By x1FastGTPx in forum Off Topic Discussion
    Last Post: 01-30-2008, 04:57 AM
