Thread: Intake Gasket Repair
Results 1 to 4 of 4
  1. #1 Intake Gasket Repair
    Nov 2009
    RI
    Hi all, I am going to do the intake gaskets on my 2002 GP GT this weekend and need few questions answered before I start......thanks
    1) Will garrage tempeture...40 degrees if I`m lucky....cause any problems ?
    2) Should I use the RTV sealant that came with the gasket set ?
    3) Do the coolant elbows need a sealant ?
    4) What needs to be done to switch the coolant?...just flush and replace
    any other words of wisdom that anyone would like to share will be appreciated........thanks again
  2. #2 Re: Intake Gasket Repair
    Donating Users Ibwrong's Avatar
    Oklahoma City
  3. #3 Re: Intake Gasket Repair
    Quincy, Mass
    use the aluminum gasket not the plastic one. get a space heater so your not freezing the garage. and go over the links above a few times before you start. be sure to have injector o-rings, there are 2 on each injector.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Intake Gasket Repair
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    yep i'd put rtv, grey or black, on the coolant hoses and too replace antifreeze, just flush and use the storebrand advance auto antifreeze cause prestone makes it, . and x2 on the heater, u'll freeze!
  1. intake gasket
    By bensett004 in forum General Tech Discussion
    Last Post: 11-26-2009, 01:13 PM
  2. Intake plenum gasket
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 10:09 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. Intake gasket
    By mjt in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-12-2009, 12:28 AM
  5. Intake Gasket Replacement
    By wicked50 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 06:21 PM
