Thread: ambient air temp sensor
Results 1 to 20 of 27
  1. #1 ambient air temp sensor
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    hoping someone could help me out on this. i'm trying to find where the ambient air temp sensor harness enters the cabin, and hooks into the i/p dash harness. i added the rearview with compass and temp, and i know that the stock harness is up front in the bumper, but i dont have the auto hvac, so those wires dont end up behind the hvac controls.... where do they stop?
  2. #2 Re: ambient air temp sensor
    GT Level Member Euro's Avatar
    Roselle, IL
    If it's the sensor that tells the climate control/mirror outside temp, it should be somewhere behind the front bumper. That's where I've heard it was. I haven't looked for myself though.
    2000 Regal GS - 190k - Black over Storm Gray Metallic - 9" K&N/AL104's/Borla/GP polished tq stars/turd
    2009 Impala LT - 62k - Car Seat Mobile
    2000 Grand Prix GT - 96k - Sold/RIP
  3. #3 Re: ambient air temp sensor
    SW Chicago Suburbs
    Quote Originally Posted by Euro View Post
    yeah i know where that is, i want to know where wires disapear to once inside the dash... i.e. what plug they go to--- (my gtp doesnt have the auto cc, but the harness for the temp sensor is present in the bumper, but i dont see the unused auto CC plug behind the radio/manual CC in the dash... trying to figure out where the wires stop.
  4. #4 Re: ambient air temp sensor
    Saraland Alabama
    could they be wrapped up in the harness near the radio?
  5. #5 Re: ambient air temp sensor
    SW Chicago Suburbs
    Quote Originally Posted by archemedes View Post
    not sure.... i did just notice in my wiring location diagram that there's an inline connector for the sensor under the washer fluid tank/near battery, i'll need to look there and see if it's connected there or not. if it is, then it at least makes it to the inside of the car.... I i think it was farnsworth that had his GF's dash all apart searching for a short.... need him to pop in and point out where the main I/P harness connects to the wire bundle that comes into the car from the engine compartment.
  6. #6 Re: ambient air temp sensor
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    ***Bringing thread back from dead*** (only because the original poster signed on yesterday, so this should get answered, and there's no other threads in the forum that have this )
    Hey man, I need to find the sensor in the bumper... my thermometer has gone wacko (said it was negative (-36*) today.... it was closer to 95*), and I need to replace it.
    Thanks!!!!
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  7. #7 Re: ambient air temp sensor
    Tyler, TX
    Alright, well with lots more searching, and some feeling around on the car, I finally found the sensor. It's not something you can see...easily.
    The best way to get to it is to go the front of your car and reach in the large opening in the bumper on the left. Then feel up and back, against the "wall" opposite side of you. It's attached with a christmas tree and just pops out. The sensor is connected with a regular plug. That's all you need to disconnect to remove it.
    *hint* If you were to take the christmas tree out and let the sensor dangle, you would see it though the passenger side "lower fashia" in front of the radiator....
    Here's a pic of the sensor
  8. #8 Re: ambient air temp sensor
    Tyler, TX
  9. #9 Re: ambient air temp sensor
    sweet thanks, so its easy to change and hoe much is the part?
    mine is saying like 40-60 degrees everyday and does not change at all.
  10. #10 Re: ambient air temp sensor
    Tyler, TX
    yeah, once I found it .... took all of a minute. I did "practice" swapping it out, just to make sure I could find the friggin sensor.....
    part is between $10 and $20. I still need to call my local dealer to see if they have one in stock. My local dealer was closed, so I called one in Colorado (time zone change) to get the info. If they have it in, then I'll swap it out tomorrow. Disconnecting it did reset the temp... I'm also crossing my fingers and hoping that fixes it
    oops, realized I left out the part number... it's 10248414
  11. #11 Re: ambient air temp sensor
    ok thanks, let me know if that fixes the problem
  12. #12 Re: ambient air temp sensor
    Tyler, TX
    from what I read... it won't.... but hey, at least it reads 90* out instead of -36*!!!
  13. #13 Re: ambient air temp sensor
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    not to hijack the thread but does anyone know if all grand prixs have that sensor cause i crashed and my bumper broke off and i dont see anything there not even wires.
  14. #14 Re: ambient air temp sensor
    Tyler, TX
    I don't know. Some of the descriptions that I came across were fairly radical (dual climate control yadda yadda yadda). GM uses this everywhere in the lineup as well.
    The harness loom that the wire come off of is the one in FRONT of the radiator. You can't see it from the engine bay, the actual harness runs between the radiator and the front bumper cover. There is just a small loom with the one connector that comes down off the main harness for the sensor. I think you'd know if it was there since you just did a bunch of body repair. There is also a hole in one of the plastic air dams that the connector harness runs through.
    (hope that helps)
  15. #15 Re: ambient air temp sensor
    Jul 2010
    TX
    i have a feeling the harness came off cause i see some wires torn on the right side of my car (pulley side), under turn signal assembly. and i couldnt tell wether they were for my horn, foglight, or the sensor. crash wasnt too bad. just took the right side of my bumper completely off.
  16. #16 Re: ambient air temp sensor
    Tyler, TX
    hmmm.... I dunno, cuz this thing is alll by itself, not really near the blinker/fogs. That's too far over. This is almost directly below the black honeycomb intake.
  17. #17 Re: ambient air temp sensor
    any update yet???
  18. #18 Re: ambient air temp sensor
    Jul 2008
    sumter,south carolina
    glad i clicked on this... i always wondered what the hell that sensor was. now i know
    02 GTP with mods 05 GP for DD
  19. #19 Re: ambient air temp sensor
    Tyler, TX
    yeah, replaced it for $12... and 1 minute of work... fixed it. very happy now.
    Sorry for not updating, been busy.
  20. #20 Re: ambient air temp sensor
    ok great, did you just go to the dealer and ask for that part number and they gave you the sensor?
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. how long and what temp in the oven to separate corner lense?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-15-2008, 02:40 AM
  3. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
  4. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
  5. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
