Thread: Ihave 4 degrees of kr
Results 1 to 8 of 8
  1. #1 Ihave 4 degrees of kr
    GXP Level Member ryangtp89's Avatar
    Maine
    I got my ls1m scanner today, well its half mine and half my friends but anyways i took my car out and i clicked the performance shift and floored it, it got up to 4 degrees of car at wot. I only have a cai and a 1.0 pcm soo whats going on and what can i do about it ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: Ihave 4 degrees of kr
    Saraland Alabama
    when was the last tune up? what brand of gas?
  3. #3 Re: Ihave 4 degrees of kr
    SE Level Member Kyle650's Avatar
    Feb 2008
    Maine
    maybe that scanner just likes my car better man, being that i only got 0.60 degrees haha
  4. #4 Re: Ihave 4 degrees of kr
    Maine
    Like what do you mean by tune up ? and I only use 93 octane anywhere that has it.
  5. #5 Re: Ihave 4 degrees of kr
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    That amount of KR has been seen in totally stock cars. You have a CAI so potentially you have potentially a greater volume less restictive incoming air flow, however, there has been no mods to allow the air out. A 3" DP should help some.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Ihave 4 degrees of kr
    Saraland Alabama
    tune up is change plugs, inspect wires, change pcv valve, and fuel filter. 93 octane doesn't tell anything what brand (as in is it top level or wal mart) a bunch of the stations here just got busted adding water to their tanks (luckily none I go to)
  7. #7 Re: Ihave 4 degrees of kr
    Maine
    Ohh i see, yea ill be doing a tune up sometime this spring, ill be getting ready to get my supporting mods finished so i can move down on the pully size.
  8. #8 Re: Ihave 4 degrees of kr
    Maine
    Haha i think it likes me better, cause i just did the 0-60 and my best time was 5.99 seconds. and i log my kr and it was doing 1.60 degrees of kr constint, soo ill get that taken care of.
