Thread: Recommended Trans Fluid
Results 1 to 20 of 22
Threaded View
  1. #4 Re: Recommended Trans Fluid
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    I do not believe Dexron VI is a full synthetic. I am a solid believe in full synthetic transmission fluid. It helps reduce temps, lasts longer and provides better protection.
    Now, that all said, I had never considered using a thicker fluid (more viscous) until I met Trannyman. I would have never done so out of fear the pump would not do well with it. But Trannyman I believe runs a bit thicker fluid (I will let him give the details if he so chooses) and his reputation speaks for itself. So in my mind, Im thinking, and Trannyman correct me if needed, that a slightly thicker full synthetic may be a good combo.
    But again I know fluids, but trannyman knows trannys and he would be the better source of information in this case.
    Of the two Dexron VI bottles Ive seen, neither claims to be a full synthetic anywhere that I could find. An while I'm on the topic of Dex VI, I wanted to mention that Wal-Mart has there own DexVI now for >$3 a quart. Bout half the price of the other DexVI's Ive seen.
    An before anyone rags on "Supertech" I started using the DexIII stuff after a local recommended it telling me how cheap it was an that he had changed it yearly on three vehicles using SuperTech DexIII all with good experiences. Thats no proof of anything but if the DexIII has treated me an him both well, I see no reason not to believe the VI would be good as well. An at about half the price of the "name brand" stuff its cheap preventative maintenance to change.
    As far as your opinion on synthetic tranny fluid, I agree, but only on new rebuilds or new trannys. I'm against switching to synthetic once it has a fair amount of miles on it. Ive read to many peoples accounts of switching an then describing it as being "too slick" for the trans to grab.
    Also after reading your post I went an found where Dave talks about his own mix an I would be willing to try that as well. Even if I had to buy 5gallons. But it sounded like he could ship out his special 5 or 6qts of special blend an then we dilute that with DexIII in a 5gallon bucket. I'd even wanna try his mix with diluted with DexVI see if we cant make the perfect fluid
    PS. Here is the thread that Dave talks about this fluid a little bit. What Tranny Fluid Should I Run
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  1. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  2. My New Trans Am WS6!!
    By x1FastGTPx in forum Visual/Body Modifications
    Last Post: 07-12-2008, 04:38 PM
  3. trans help!
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-27-2008, 05:29 PM
  4. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
