voltage does not tell the whole story...amperage(draw) does...you can have high volts and if you dont have enough amps, you will not have enough power to make the motor turn over properly...this is why batteries are rated in cca and ca(cold cranking amps and cranking amps) dont go by voltage, get the proper amperage draw.
