Thread: interior lights very dim,shutting radio off.please help
Results 1 to 7 of 7
  1. #1 interior lights very dim,shutting radio off.please help
    Nov 2009
    ellenville n.y
    I am new here and figured i would ask for some help from someone who has possibly went through a similar issue.i bought a 1997 gp/gt and the guy i bought it from told me the interior lights just stopped working and it was prob a blown fuse.I didn't care much cause i liked the rest of the car but it turns out he lied.When i decided to check it out i found the fuse was missing.So iput a fuse in a tahdah,LIGHTS.So i think i fixed it but it turns out a couple mins later they go dim and the radio shuts off..I pull the fuse and the radio comes back on.I put the fuse back in and the lights are still dim and the radio keeps turning on and off,so i pulled the fuse and the radio is fine.I am assuming the po figured that much out and left the fuse out.I personally would like to figure out how to fix the lights inside.It's kinda one of those taken for granted things that i am going nuts without.Any help with this issue would be greatly appreciated.Thanks
  2. #2 Re: interior lights very dim,shutting radio off.please help
    SE Level Member mksiler's Avatar
    chapel hill
    Not sure if this is going to fix your problem but I am having an issue with my interior lights dimming. The headlight swithch/dimmer is going bad. I will be replacing it soon. Oh, and my radio is working fine.....I do have a burning mell and i know its comming from the headlight switch! So I would take that small door off thats on the driver side and check it.....You could have some melted wires or chafed wires touching!
  3. #3 Re: interior lights very dim,shutting radio off.please help
    Nov 2009
    ellenville n.y
    I'll check it out this weekend.Thanks
  4. #4 Re: interior lights very dim,shutting radio off.please help
    So the car starts fine and will run fine for a while as well?
  5. #5 Re: interior lights very dim,shutting radio off.please help
    Nov 2009
    ellenville n.y
    Yes,the car starts and runs fine.I did look at the switch and the wires and all looks well.I am still going to try switching it out to see but i am doubting it honestly will fix the prob.It almost seems like a wire is shorting out somewhere,Possibly a relay issue?I dunno
  6. #6 Re: interior lights very dim,shutting radio off.please help
    chapel hill
    Changed the switch out and it fixed my dimming problem! So hopefully this will fix your problem. Never seen the dash lights so bright! I only had the gtp for 8 months.
  7. #7 Re: interior lights very dim,shutting radio off.please help
    SE Level Member trickytransam's Avatar
    Michigan
    Pull the radio. I'm wondering if he put in an aftermarket radio, hacked the harness and confused the dimmer lead for a power lead and it's backfeeding the lights.
  1. Interior lights replaced with LED's - WOW what a difference
    By ohioGTP in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2015, 02:19 PM
  2. Interior lights randomly blink on
    By g347954 in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2009, 02:56 AM
  3. problem with the interior lights?
    By riseagainst4288 in forum General Tech Discussion
    Last Post: 07-24-2009, 08:37 PM
  4. Interior lights from red to blue
    By robahr24 in forum Visual/Body Modifications
    Last Post: 08-26-2008, 04:46 PM
  5. Interior Lights:(
    By RichCresci in forum General Tech Discussion
    Last Post: 07-08-2008, 11:29 PM
