Thread: Teenage girl needs help!
Results 1 to 20 of 20
  1. #1 Teenage girl needs help!
    Nov 2009
    Michigan
    Hi, I have a 1998 Gand Prix GT with a 3.8L engine. I need help diagnosing my problem, I need to get it fixed.
    The problems I'm encountering is irratic idling. It will jump from 0-1000, and then down to 600, etc. It occasionlly stall out, and my dad told me to ask if it has a rev limiter? At 3500-4000 RPM it tends to be "starving for fuel."
    The check engine light is on and the code is Mass Air FLow Bank 1 too lean.
    Dad checked fuel filters, and cleaned Mass Air flow and nothing yet.
    Please help!!
  2. #2 Re: Teenage girl needs help!
    it has a rev limiter of 4000 when in park. the problem youre experiencing is a vacuum leak. take a can of carb cleaner and spray it around the engine bay. when you hit a spot that the idle changes from the spray being ingested in the engine then youve found your leak. youll more than likely have to change a gasket.
  3. #3 Re: Teenage girl needs help!
    GTP Level Member SuperSport's Avatar
    Michigan
    MAF could be dead. Unplug it and see if it helps. If it does, then you know the MAF is bad.
    Welcome, BTW. Where in MI do you live?
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: Teenage girl needs help!
    Nov 2009
    Michigan
    Near the Detroit area.
    With MAF un-plugged, the car didn't do any better.
    Will try to see if there is a vacuum leak and let you all know!
    Thanks
  5. #5 Re: Teenage girl needs help!
    Michigan
    Hell yeah Detroit! Same here.
    Good Luck with your issue. Really dont know what else it could be. Theres more people here with more knowledge than me.
  6. #6 Re: Teenage girl needs help!
    Donating Users blowfishRus6's Avatar
    g.a.
    teenage girl needs help......
    humm
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Teenage girl needs help!
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by blowfishRus6 View Post
    humm
    lmao i thought the same thing when i read title
    02 GTP with mods 05 GP for DD
  8. #8 Re: Teenage girl needs help!
    GT Level Member Joe m's Avatar
    mesa,az
    pick me pick me!!! no but really i agree with bio. check for the leak.
  9. #9 Re: Teenage girl needs help!
    Banned - Busted For Scamming
    Feb 2009
    If it idles high and the throttle is slow to come down to idle and it runs like crap its likely to be the maf. The way you spot a bad maf is if the quality of running does not change when you unplug it, meaning it was giving false signals to begin with.
  10. #10 Re: Teenage girl needs help!
    Wooster, Ohio
    also MAF is pretty sensitive, so what did your dad use to clean it? Also sounds more like TPS to me...varying idle like that normally goes to TPS from what i've seen. As long as its just at idle and not a driveabilty problem thats my vote!
  11. #11 Re: Teenage girl needs help!
    Wausau, WI
    I would lean towards the vacuum leak as well which would explain both the crappy idle and the lean code you are experiencing. If you were having problems just with the idle, I would also check the IAC(idle air control) on your throttle body. Take it out, clean it, and put it back in. But I would say it is far more likely a vacuum leak than anything else. Was any other work done under the hood just before this started happening?
  12. #12 Re: Teenage girl needs help!
    Oct 2008
    Northern Illinois
    Vac Leak
  13. #13 Re: Teenage girl needs help!
    Donating Users kfish's Avatar
    Ohio
    Quote Originally Posted by BwolfGT View Post
    Vac Leak
    Vac Leak x2
  14. #14 Re: Teenage girl needs help!
    SE Level Member Enzo354's Avatar
    USA
    This thread got replied to pretty fast haha.
  15. #15 Re: Teenage girl needs help!
    SE Level Member 00 grand prix's Avatar
    utah
    my car was doing the same thing,and it ended up being my MAF sensor
  16. #16 Re: Teenage girl needs help!
    if not a MAF sounds like an upper intake manifold gasket leak and its sucking in air like others said spray some cleaner around the maifold and see if the idle goes up, if so its sucking in the cleaner.
  17. #17 Re: Teenage girl needs help!
    MO
    i agree sounds like upper intake manifold gasket. one of the few things i really would be able to diagnose lol
    <brandonl2000> LMAO D!!
  18. #18 Re: Teenage girl needs help!
    Manitoba
    I have a 2000 grand prix gt and my idle was all over the place. Had all kinds of stuff checked and couldn't figure out what it was. A couple of weeks later my battery was totally dead and had to replace it. Problem was gone and hasn't come back in over 3 years.
  19. #19 Re: Teenage girl needs help!
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    haha the next time i have a problem im gona put something about women in the title cause u guys jumped all over this problem
    silver 2003 Grand Prix GT List is on it's way to be updated
  20. #20 Re: Teenage girl needs help!
    SE Level Member trickytransam's Avatar
    Michigan
    My bets are on the MAF.
    Just for good measure, replace the lower manifold gaskets and upper intake while your at it.
  1. Power Steering is SCREAMING. HELP A GIRL OUT!
    By Princess in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:16 PM
  2. New girl here
    By katesgrandprix in forum Introductions/Noob Questions
    Last Post: 10-19-2009, 11:32 AM
  3. New girl!
    By pontiacchantel in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 09:57 PM
  4. New Girl in Town
    By Kate in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 07:33 AM
  5. New Girl in AZ
    By GPpunk in forum Introductions/Noob Questions
    Last Post: 07-04-2009, 05:57 PM
