Thread: Loud Humming noise... What is it?
Results 1 to 14 of 14
  1. #1 Loud Humming noise... What is it?
    SE Level Member brownb66's Avatar
    Nov 2009
    Battle Creek
    Okay so for the past few months there has been a terribly loud humming noise coming from somewhere in the front of the car, whenever you go 25+ mph. It's really loud at 45 & 70 mph. Whenever you are turning right, or going around a curve the sound totally disappears and it doesn't come back until you go back to straight forward or turning left. I thought it was the driver's side wheel bearing so I just put a whole new hub in and it's still there! Could it possibly be my passenger side wheel bearing? I know the one I replaced needed to be because when I took it out it was in bad condition. Any advice on what this could be would be helpful. The car does vibrate a little at higher speeds, but its mostly just a rediculous loud noise and I am just really curious if it could be anything else besides the other wheel bearing... thanks in advance.
    Car - 2001 Pontiac Grand Prix GTP
  2. #2 Re: Loud Humming noise... What is it?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Did u check your tires to see if there out of balance or bad?
    It could be the other wb too?
  3. #3 Re: Loud Humming noise... What is it?
    Charles City, IA
    It is the passenger side. When you turn right it takes the weight off of it so the sound goes away.
    SMGPFC Two Nipple General
  4. #4 Re: Loud Humming noise... What is it?
    Georgia
    Having the exact same issue. Was a solution ever found?
  5. #5 Re: Loud Humming noise... What is it?
    Topeka, KS
    Could be your tires as well. Could have a broken belt inside them or they are horribly out of balance.
  6. #6 Re: Loud Humming noise... What is it?
    Nov 2009
    Grand haven
    Wheel bearing!!!
  7. #7 Re: Loud Humming noise... What is it?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    ^^x2.
    if not the wheel bearing it could be the outer tierod, but my bet's on the former.
  8. #8 Re: Loud Humming noise... What is it?
    Georgia
    Thank for the info. I am just about to replace the drivers side CV shaft. The wheel bearing on the drivers side was replaced last week as was the CV shaft on the passenger side.
    Symptoms:
    Speed variable humming (starts at about 10-20mph)
    No change when trans put in N
    No change when going straight or left.
    Disappears completely when the steering wheel is turn slightly (5 deg) to the right
    ABS would engage during normal stop (stopped after DS hub replaced)
    Tires are cupped but they were cupped before issue appeared (had bad balance right out of store after a rotate and balance one wheel was 2oz out)
    Tried running 40psi in front tires with no change
    Just had alignment and tires rotated/balanced on 5/10
    Jacked car up and ran it with no humming
  9. #9 Re: Loud Humming noise... What is it?
    Outer Space
    mines doing that now... its a wheel bearing in my case.
    02 GTP 13.6 @ 100mph - SOLD
  10. #10 Re: Loud Humming noise... What is it?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    its for sure the hub? what about a bad axel?
  11. #11 Re: Loud Humming noise... What is it?
    Michigan
    definitely hub.
  12. #12 Re: Loud Humming noise... What is it?
    Georgia
    Just finished changing the LS CV shaft. Sound still there. The only thing I have not changed is the RS hub. I still have the hub from the LS, may put that in to see if it helps.
    Did notice one thing. When I pulled the the old LS CV shaft out the spline shaft in the differential for lack of a better term "wobbled". It was sagging to 6 o'clock and I could move it around like a joystick. Is this normal?
    Thanks
  13. #13 Re: Loud Humming noise... What is it?
    Nov 2009
    Battle Creek
    For sure its the hub and wheel bearing assembly. If you changed the one side and still have it, then its gotta be the other! I changed both and now I got smoooth sailing, no more loud humming noise thank god!
    01' Pontiac Grand Prix GTP... work in progress.
  14. #14 Re: Loud Humming noise... What is it?
    Georgia
    It was the the RS hub. Makes sense when you think about it. During a left turn all of the stress is on the RS hub and visa versa. At 140K they both needed to be changed anyway. Thanks
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. Loud noise at speed
    By ionroller in forum 04+ Specifics
    Last Post: 10-27-2009, 02:26 PM
  3. Loud Rattling Noise
    By Dangerous313KidInAPrix in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 05:18 PM
  4. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  5. new humming noise??!!??!!
    By Morris 04 GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2009, 09:33 AM
