^^x2.
if not the wheel bearing it could be the outer tierod, but my bet's on the former.
Thank for the info. I am just about to replace the drivers side CV shaft. The wheel bearing on the drivers side was replaced last week as was the CV shaft on the passenger side.
Symptoms:
Speed variable humming (starts at about 10-20mph)
No change when trans put in N
No change when going straight or left.
Disappears completely when the steering wheel is turn slightly (5 deg) to the right
ABS would engage during normal stop (stopped after DS hub replaced)
Tires are cupped but they were cupped before issue appeared (had bad balance right out of store after a rotate and balance one wheel was 2oz out)
Tried running 40psi in front tires with no change
Just had alignment and tires rotated/balanced on 5/10
Jacked car up and ran it with no humming
