Thread: LIM gaskets
Results 1 to 6 of 6
  1. #1 LIM gaskets
    SE Level Member jmac's Avatar
    Nov 2009
    hatfield
    Hello Im new to this forum and I have a question. I have a 1997 grand prix gt 3.8. I have the famous coolant leaks and Im going to change out the UIM and do gaskets on the LIM.There are two gasket kits one with location pins and one without. How do I know which one to get or do I have to do the tear down first.Im sure this has been mentioned just not sure where to look. Thanks
    www.jmfabrications.com
  2. #2 Re: LIM gaskets
    Outer Space
    Make sure you get the Metal LIM gaskets. The guide pins are on the rubber sides. I bought a felpro one and it had it.
    Also check this video if you need some guidance. Helped me.
    http://www.grandprixforums.net/lim_lifter_video.php
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: LIM gaskets
    Donating Users kfish's Avatar
    Ohio
    a 97 block does not have the locating holes on the sides of the lower intake. if you get one with the pins youll need to snip them off.
  4. #4 Re: LIM gaskets
    Like mentioned, get the LIM gaskets from teh dealer. There won't be a choice of first or second design.
    As for the locating pins. You don't need to snap them off. They simply hang over the edge of the block w/o anything to grip.
    Note the pin holes to the left and right of the lifter valley.
    And on a 97, there are no holes.
  5. #5 Re: LIM gaskets
    PA
    Agreed. Doesn't matter what gaskets you get, they will work on a 97 either way. No issue.
    2001 GSE
  6. #6 Re: LIM gaskets
    Nov 2009
    hatfield
    I thank you for all your help
  1. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
  2. What are all these gaskets?
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 02:22 AM
  3. Intake gaskets
    By HumanWeapon in forum General Tech Discussion
    Last Post: 11-06-2009, 02:52 PM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  5. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
