Thread: Intake gaskets
Results 1 to 13 of 13
  1. #1 Intake gaskets
    Minnesota
    Aight i have leaky intake gaskets. and i was just wondering what people recommend i buy for new ones?
  2. #2 Re: Intake gaskets
  3. #3 Re: Intake gaskets
    Outer Space
    x2 Metal LIM gasket FTW
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: Intake gaskets
    Minnesota
    aight now where would i find those gaskets?
  5. #5 Re: Intake gaskets
    May 2008
    staten island,NY
    the dealership, or you can get them from zzp, replace the valve cover gaskets too while you're in there
  6. #6 Re: Intake gaskets
    They should be the normal replacement the dealer hands you. Dealer, Intense-Racing or ZZP, all have them.
  7. #7 Re: Intake gaskets
    PA
    Personally, on a stock vehicle, or mildly modified, the plastic ones are fine. The metal ones are good if you are pushing high boost. But even ZZP recommends the plastic ones for stock applications.
    2001 GSE
  8. #8 Re: Intake gaskets
    the metal dont break down and leak as easily, how can you even justify using the plastic ones anymore?
  9. #9 Re: Intake gaskets
    GTP Level Member SuperSport's Avatar
    Michigan
    Quote Originally Posted by Zef_66 View Post
    My car aint even supercharged and mine are leaking.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  10. #10 Re: Intake gaskets
    Charles City, IA
    Put the metal ones in. If the plastic ones where fine y did they change them for the series III?
    SMGPFC Two Nipple General
  11. #11 Re: Intake gaskets
    I've had a lot of experience with the LIM gaskets. Before the metal were available I found that in as little as 20K miles the plastic ones would warp and begin to deform. That was on a stock motor running a 180 thermostat.
    Metal has never been found to deform or cause issues. I've pulled them with up to 60K miles on them. Each time they come out looking the same as they went in w/o any symptoms or signs of leaking.
    My opinion is anyone that tells you to use the plastic framed ones is doing you a great disservice. Spend the money once and do the job once with the aluminum gaskets.
  12. #12 Re: Intake gaskets
    Moore, Oklahoma
    The metal gaskets don't cost anymore than the plastic though the dealer. IMO, don't be a cheap ass, get the metal and get an overall better gasket that will outlast the original plastic hands down, stock or not.
    As far as ZZPs "advice", its been proven they give bad advice from them so **** them. Common sense is the key here. Why put something on your motor that'll last a few years when you can put something on that will last damn near the life of the motor? A no brainer to me. Especially for a few bucks.
    Dealership would be the place to go, 04 GP GTP should work. I had a PN handy but I cannot find it at the moment. If i do, i'll post it up....
    Shawn W. Larsen
  13. #13 Re: Intake gaskets
    Wausau, WI
    I got these numbers from a different thread, but I believe the metal LIM gaskets are PN: 89017825
    Can anyone confirm this?
    These numbers were taken from the LIM video thread
  1. Suggestions while replacing intake gaskets
    By 918GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 09:18 PM
  2. intake gaskets
    By dpmeeks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2009, 01:24 PM
  3. HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    By 99gpse in forum General Tech Discussion
    Last Post: 02-23-2009, 05:02 PM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  5. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
