Thread: cost to replace a sway bar? Do these crack?
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
andremike cost to replace a sway bar?... 11-17-2009, 11:06 AM
Jakegday Re: cost to replace a sway... 11-17-2009, 11:13 AM
Zef_66 Re: cost to replace a sway... 11-17-2009, 11:22 AM
andremike Re: cost to replace a sway... 11-17-2009, 11:48 AM
Zef_66 Re: cost to replace a sway... 11-17-2009, 12:01 PM
andremike Re: cost to replace a sway... 11-17-2009, 11:25 AM
Zef_66 Re: cost to replace a sway... 11-17-2009, 11:45 AM
matt5112 Re: cost to replace a sway... 11-17-2009, 11:39 AM
andremike Re: cost to replace a sway... 11-17-2009, 12:02 PM
matt5112 Re: cost to replace a sway... 11-17-2009, 12:05 PM
SnowDrift Re: cost to replace a sway... 11-17-2009, 12:26 PM
andremike Re: cost to replace a sway... 11-17-2009, 12:29 PM
SnowDrift Re: cost to replace a sway... 11-18-2009, 07:23 AM
Zef_66 Re: cost to replace a sway... 11-18-2009, 11:02 AM
SnowDrift Re: cost to replace a sway... 11-18-2009, 12:26 PM
matt5112 Re: cost to replace a sway... 11-17-2009, 12:37 PM
andremike Re: cost to replace a sway... 11-17-2009, 12:42 PM
matt5112 Re: cost to replace a sway... 11-17-2009, 12:54 PM
Jakegday Re: cost to replace a sway... 11-17-2009, 02:55 PM
andremike Re: cost to replace a sway... 11-17-2009, 03:10 PM
Jakegday Re: cost to replace a sway... 11-18-2009, 08:40 AM
Pittman06 Re: cost to replace a sway... 11-17-2009, 11:20 PM
SnowDrift Re: cost to replace a sway... 11-18-2009, 07:24 AM
toolguy Re: cost to replace a sway... 11-18-2009, 08:02 AM
matt5112 Re: cost to replace a sway... 11-18-2009, 10:13 AM
toolguy Re: cost to replace a sway... 11-18-2009, 12:39 PM
matt5112 Re: cost to replace a sway... 11-18-2009, 12:54 PM
Pittman06 Re: cost to replace a sway... 11-18-2009, 10:21 AM
QUICKSILVER462 Re: cost to replace a sway... 11-20-2009, 12:43 PM
Tony48 Re: cost to replace a sway... 12-24-2011, 02:27 PM
Tuner-Extraordinaire Re: cost to replace a sway... 12-24-2011, 02:38 PM
Odi Re: cost to replace a sway... 12-24-2011, 02:39 PM
mrlogic1234 Re: cost to replace a sway... 12-25-2011, 12:00 AM
bps02gtp Re: cost to replace a sway... 12-26-2011, 11:39 AM
TheOtherNick Re: cost to replace a sway... 12-26-2011, 11:44 AM
matt5112 Re: cost to replace a sway... 12-26-2011, 01:19 PM
  1. #1 Re: cost to replace a sway bar? Do these crack?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by andremike View Post
    Please recommend which ones to buy, and from where...
    i ended up going with the Sherman brand from rockauto.com
    they have served me quite well
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: cost to replace a sway bar? Do these crack?
    Wooster, Ohio
    heres a little secret on the sway bars, check out Summit Racings website, the GM Performance Parts sway bar is dirt cheap. Couldn't find a OE replacement for under 110 until i checked here, the main store is 30 minutes from me so i'm not sure how steap there shipping is
  3. #3 Re: cost to replace a sway bar? Do these crack?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by Pittman06 View Post
    Thanks for the tip. I'm about 1 1/2 hrs. from their store, but I've gotten plenty of things from there. I'll look into it.
  4. #4 Re: cost to replace a sway bar? Do these crack?
    Guam
    I got the GMPP sway bar kit for $80 and installed it myself on my 99.
    Yes they do crack and break, other GM vehicles has the same issue. The problem is, the bars are hallow and rust out. The bars mostly snap or crack at the ends, where the steel was pressed down to be flat.
    One end of mine was cracked, the other completely broken off.
    The replacements are solid steel, the way the bar should have been from the beginning.
  5. #5 Re: cost to replace a sway bar? Do these crack?
    Quote Originally Posted by toolguy View Post
    Front is still tubular.
  6. #6 Re: cost to replace a sway bar? Do these crack?
    Guam
    This is the kit I got from my local dealer and getting the P/N from gmpartsdirect.
    It is a solid steel bar...
    GM Sway Bar Kit~Grand Prix~Impala~Monte Carlo~1997-2005:eBay Motors (item 390111578297 end time Nov-27-09 09:34:15 PST)
  7. #7 Re: cost to replace a sway bar? Do these crack?
    true
  8. #8 Re: cost to replace a sway bar? Do these crack?
    Wooster, Ohio
    GM Performance 12498643 - GM Performance Anti-Sway Bars - Overview - SummitRacing.com
    $65 with endlinks, used one of these on my Sisters 98 GT and looks like much better quality then junk OE!
  9. #9 Re: cost to replace a sway bar? Do these crack?
    HUDSON
    I put on the GMPPP 34mm bar, came with poly end links and frame mounts, it was 65$, best money spent on the car yet. It does take some trial and error getting it to fit properly because the larger diameter tends to interfere with other parts around it. I have read it can be put in up, or down, depending on your car.
  10. #10 Re: cost to replace a sway bar? Do these crack?
    Dec 2011
    House springs, Mo
    For any of you folks that can weld or know someone who really can weld: jack it up at least a foot, free the bar from the end links, loosen the bushings sufficiently to allow you to move it left and right clamp and tack it and be sure to run good tacks across the face where the 2 pressed together ends meet, run a full pass over everything and reinforce the cracked areas with a multipal stringers. Cost two dollars in welding rod. Keep a fire extinguisher handy just in case. Put a peice of tin between the engine and the bar when you're welding and cover the brakes with a welding blanket or another peice of tin. Wrap the weld with fiberglass and let it slow cool. Took me about an hour 5 years ago, still holding. If you can TIG weld so much the better, no sparks and a much smaller heat effected zone.
  11. #11 Re: cost to replace a sway bar? Do these crack?
    Out West
    For the cost it's better to just buy a sway bar...and upgrade at the same time.
    Whine with your Cheese?
  12. #12 Re: cost to replace a sway bar? Do these crack?
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ this guy is crazy but for once he speaks truth.
  13. #13 Re: cost to replace a sway bar? Do these crack?
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Mine has been completely broken on the GTP for about a year. Shop quoted me a similar price.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  14. #14 Re: cost to replace a sway bar? Do these crack?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    ok now im confused. this whole time i was under the impression that solid sway bars are way better than hollow. but u guys make it seem like GMPP is the way to go. so what should i get? cuz mine is completely broken on both sides lol so i have no sway bar.
  15. #15 Re: cost to replace a sway bar? Do these crack?
    Charles City, IA
    Just get the dorman bar.
    SMGPFC Two Nipple General
  16. #16 Re: cost to replace a sway bar? Do these crack?
    GMPP is slightly more than the price of dorman and you get a rear as well.
    Consider I've seen cars snap the rear sways in the same fashion.
  1. Crack pop clunk
    By Green97GTP in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2009, 06:47 AM
  2. Crack heads!
    By SlowM90 in forum The Rant Forum
    Last Post: 09-07-2009, 11:43 PM
  3. cost of top swap
    By skidoojames151 in forum General Tech Discussion
    Last Post: 08-05-2009, 09:44 AM
  4. What should i use to repair a windshield crack?
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2008, 08:41 PM
