Thread: tb spacer info needed
Results 1 to 2 of 2
  1. #1 tb spacer info needed
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    i hear that tb spacers mess with the coolant flow. is this a problem? will it cause cooling problems 2 my car? any1 have 1 installed i'd like2 know how it works. ty.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  2. #2 Re: tb spacer info needed
    it works by stopping coolant flow through the TB, essentially cooling intake temperatures down, but frankly its one of the biggest wastes of money you can do on your car. save yourself the money and just dont buy one.
    however, the coolant flowing through the throttle body is where some of the flow to the rear head comes from so if you block that off either at the TB or the LIM then you will allow the rear head to run hotter. to alleviate this problem you need to open up the area on the drivers side of the LIM that is where the remainder of the rear head flow comes from. this will balance it out and you can safely seal it all off.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. 06 GP wheel question - info needed.
    By daiadvisor in forum General Tech Discussion
    Last Post: 07-14-2009, 06:25 PM
  3. Head unit info/comparison, opinions, and specs needed
    By Trannyman95 in forum Audio, Security & Visual Electronics
    Last Post: 12-07-2008, 06:15 PM
  4. help: TB sensor pin-outs and wiring info needed
    By shaferz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 07:09 AM
  5. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
