Anybody have anything?
While driving yesterday, the trans was acting wierd. Would feel like it was starting out in 2nd gear, and then felt like it would go into 3rd, but felt like the TCC kept locking and unlocking. I got it home and parked it because I was busy as crap last night. Woke up this morning and forgot that there was something wrong, and tried to drive it to work. I first noticed that the car hesitated a touch after pushing the gas down. I then noticed that it would not shift into 1st gear.
I pulled over and flipped through the aeroforcetech gauge to see if I could see anything immediately wrong, and the only thing that came up wierd was the TP% and TP voltage were both stuck at zero, no matter what I did with the gas pedal. I got the car home, and pinned between the two outside wires on the L67 TP plug, and had 5.3VDC.
Is the 5.3VDC normal, or should that be at 12V? Of course the GTP is my DD, so for right now, my wife is stuck having my motherinlaw take her to work. Any help is appreciated!
Thanks,
Zach
edit: I can only assume that my problems yesterday are related to the TP circuit being miffed somewhere. I would imagine that inconsistant TP numbers would make the trans freak out.
