Thread: Need help removing interior pieces
Results 1 to 7 of 7
  1. #1 Need help removing interior pieces
    Norristown, PA
    im going to paint some things...need help remoing the lower peice of the dash where the shifer is, and the window switches..
    how do i remove them?
  2. #2 Re: Need help removing interior pieces
    Charles City, IA
    Open the center consul and open the cup holder and the center piece pulls out.
    The window switches just pull strait up i think.
    SMGPFC Two Nipple General
  3. #3 Re: Need help removing interior pieces
    Norristown, PA
    i was pulling on the window switch peices a little but couldnt get them.. i didnt want to break them
  4. #4 Re: Need help removing interior pieces
    Charles City, IA
    1. Apply protective coating/tape at the rear of the rear door power window switch (right and/or left door).
    2. Remove the rear door power window switch from the rear door trim panel using a small, flat-bladed tool, inserted at the rear of the rear door power window switch plastic mounting plate. Press forward in order to release the rear door power window switch mounting plate.
    3. With the rear retainer released, pull the switch to the rear and lift up to remove the mounting plate and switch.
    That is all I can find. I am pretty sure the front come out the same.
  5. #5 Re: Need help removing interior pieces
    Norristown, PA
    just tried to pull the center peice out...couldnt get it
  6. #6 Re: Need help removing interior pieces
    Charles City, IA
    You might have to use a screw driver to pry up a bit. Start at the consul and work your way forward.
  7. #7 Re: Need help removing interior pieces
    Norristown, PA
    i got it off and the first coat of paint on it! thanks man
  1. Intake blows to pieces..fire erupts
    By GT Gurl in forum General Tech Discussion
    Last Post: 10-06-2010, 08:50 AM
  2. Pieces of clutch material on my magnet...
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-26-2008, 06:36 PM
