Thread: Aftermarket Boost Gauge
Results 1 to 20 of 23
  1. #1 Aftermarket Boost Gauge
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    So I hooked up a sunpro boost gauge today... kinda in a rush before heading home from work. Well got it all installed and driving home I tested it out and it reads 20-23 Vac but when I WOT the gauge shoots to 0 and holds there til I let up.
    I connected the vac hose to the center nipple on the 3 way on top of the s/c that is orginally blocked off. I plan on disconnecting it and connecting it to the MAP sensor with a "T" tomorrow.
    Any of you guys have some thoughts on this before I go to the zone for a vac T in the morning?
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  2. #2 Re: Aftermarket Boost Gauge
    you got in the wrong vacuum line then. you need the vacuum line that is connected to the MAP, LIM, FPR, and BBV.
  3. #3 Re: Aftermarket Boost Gauge
    Wausau, WI
    how is that 160* thermostat working out for you?
  4. #4 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    Thats what I figured... like I said am gonna switch that around tomorrow
    1989 Sierra:
  5. #5 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    Excellent actually... I thought I would lose heat esp with winter time coming but I don't.
    On the highway she runs steady at roughly 165*
    If I sit Idle for 5+ minutes she climbs to about 185*
    1989 Sierra:
  6. #6 Re: Aftermarket Boost Gauge
    you realize there is absolutely no reason for you to run a 160*, right? especially with how lightly modded you are.
  7. #7 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    I know... Was flushing the coolant and wanted to change the thermo at the same time.. ended up grabbing the 160 and throwing it in.
    1989 Sierra:
  8. #8 Re: Aftermarket Boost Gauge
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    This thread has so much potential.
    subscribed.
    Engineering the impossible.
  9. #9 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    Ok... switched vacuum lines. Now I'm T'ed into the MAP sensor line...
    She is now reading 10 vac and at WOT she reads 3lbs of boost.. something is wrong here.. I know I got more boost then that
    Vacuum leak maybe?!
    1989 Sierra:
  10. #10 Re: Aftermarket Boost Gauge
    Wausau, WI
    while in park you should be getting close to -20 vaccuum and in gear it should be around -16 or somewhere close. You should be maxing out on the boost end of it anywhere between 6-10psi depending on how ported your SC is I would guess. Do you have any way to scan? If so cross reference to see what it says if it is the gauge or if you have a vac leak or some other problem.
  11. #11 Re: Aftermarket Boost Gauge
    Vacuum leak...for sure...check the "T" Fittings around the supercharger and LIM...most of the time they dry rot...or hte vacuum line on the TB...mostly likely in one of those 2...you can get the entire new GM specific lines for less than $40-$50
  12. #12 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    Found it.. the BBV Line feel off.
    Now reading -20 and 9 - 9.5 lbs of boost
    1989 Sierra:
  13. #13 Re: Aftermarket Boost Gauge
    Wadsworth, IL
    HEy I'm not real car savy I know this is kind of a stupid question but is there anyway to get the gages on the driver side door support, I know it's possible period but wondering if it's been done on a gp and where to get them and about how much would they be. I have a 05 gtp
    05 GTP w/ K&N Cold Air Intake, Dynomax Mufflers, Resonator Delete, Speed Daddy Headers, ZZP 180* TSTAT, 3800Performance 3.4" MPS, ZZP Ignition Wires & a DHP Tune
  14. #14 Re: Aftermarket Boost Gauge
  15. #15 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    1989 Sierra:
  16. #16 Re: Aftermarket Boost Gauge
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    is the bypass valve vacuum line up top a good line 2 tap in2 for a boost gauge?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  17. #17 Re: Aftermarket Boost Gauge
    Wadsworth, IL
    Ok again sry im being such a noob here so I found some pillars and wondering what gauges exactly would you guys recommend, obviously a boost gauge, but I saw one that had engine vacuum and boost in it together wondering if thats a better choice. And also wondering if Glow shift gauges are nice quality gauges or not? Thx really appreaciate it guys
  18. #18 Re: Aftermarket Boost Gauge
    Quote Originally Posted by Redbirds2230 View Post
    boost/vac in one gauge. glow shift are good gauges, i had one and liked it a lot for how cheap it was. if you had to pick three (cheap) gauges i would pick boost/vac, oil pressure, and volts. the rest of the gauges you might want or need are more expensive.
  19. #19 Re: Aftermarket Boost Gauge
    Middleboro, Ma
    I would go with the Blinker fluid level gauge, Tire pressure gauge, and the Vacuum most def....
    Just Playing... what Bio said is what I recommend.
    1989 Sierra:
  20. #20 Re: Aftermarket Boost Gauge
    Wausau, WI
    get one aeroforce, then you can switch it whenever you want and read/clear codes with it too. Get a wideband A/F IF you ever plan on having a custome tune done to it or if you are going to mod it at all.
  1. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  2. Boost Gauge?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:56 PM
  3. aftermarket fuel gauge wiring
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:09 PM
  4. boost gauge and etc...
    By Charged97 in forum General Tech Discussion
    Last Post: 02-28-2009, 04:16 AM
