while in park you should be getting close to -20 vaccuum and in gear it should be around -16 or somewhere close. You should be maxing out on the boost end of it anywhere between 6-10psi depending on how ported your SC is I would guess. Do you have any way to scan? If so cross reference to see what it says if it is the gauge or if you have a vac leak or some other problem.
