Thread: 02 GT engine/tranny issue?
Results 1 to 19 of 19
  1. #1 02 GT engine/tranny issue?
    SE Level Member Pitcrew's Avatar
    Upstate, NY
    Little question for you guys, when i step on the gas pedal to half when below 35mph, isnt overdrive suppose to kick in? And the same when over 35mph about 3/4 throttle? My GP has been fine for the past year or so, regular maintenance, oil changes when told to, and so on. Just within the past week everytime i step down and try to go, its bogs down and barely accelerates! On mon i attempted to pass a car on the thruway and when i got to about 3/4 down the "Service Engine Soon" light came on! I let off and it went away, but now anytime i try to get going, the car just revs up to 5k and it takes a good 2 sec to gain 5mpg....
    Any idea whats wrong?
  2. #2 Re: 02 GT engine/tranny issue?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    How's the fluid level. Might be the clutches. DEF get that code checked. Even though there's no light, it's frozen in the PCM and can be checked. If you can, get back to me on what the code is
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  3. #3 Re: 02 GT engine/tranny issue?
    Upstate, NY
    I have a feeling thats gonna cost me. Tomorrow when im at a vocational school, ill ask the auto tech teacher if they can check my computer.
    Hypothetically, if it isnt a code issue, what else may it be?
  4. #4 Re: 02 GT engine/tranny issue?
    Nov 2008
    My best guess would be the clutches slipping. Could be something as simple as low oil level. Or something more costly like worn out clutches. Best of luck and hopefully it's just a quick fix. Just got finished doing 2 trans builds and it's not fun nor is it cheap
  5. #5 Re: 02 GT engine/tranny issue?
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by Pitcrew View Post
    Sure I’ll play. I’ll put a nickel on it needs a tranny flush or needed one 20K ago
    And just because I have to know, you think your car might be going in overdrive? What you can’t tell when your car shifts?
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: 02 GT engine/tranny issue?
    Upstate, NY
    No codes found, transaxle fluid is still red, but a hint of brown. Talked to my dad about and after school tmw im dropping her off at the dealership....
    Cerick-Pardon the crappy explanation, but id assume that the car acts as the manual says when the car is under 35mph, and the gas pedal is pushed to half of its travel, thats that overdrive. When the car is above 35mph, and the pedal is pushed to its limit, that would be that overdrive. The car has over 138k miles on it and last i knew, at 100k the tranny was flushed as recommended. And for the shifting thing, shifting is a smooth "powerband" feeling as the overdrive would be the "sudden" burst of acceleration? right or wrong? And yes, i am 17, not to much car knowledge, but i know enough when the car is acting wrong. I will admit that i have also done somethings with this car that may have caused this issue, but im hoping none of it is the reason...
  7. #7 Re: 02 GT engine/tranny issue?
    Nov 2008
    What might these "things" be. Could help figuring things out a bit
  8. #8 Re: 02 GT engine/tranny issue?
    I think we need to correct something here... Overdrive is when the tranny's gear ratio is less than 1:1. What you're refering to is the car kicking down a gear right?
  9. #9 Re: 02 GT engine/tranny issue?
    Upstate, NY
    Things would be....and i know ill get .... for it cause its kinda abuse.....seeing how fast it goes(my brother actually had the car before me, and did this numerous times), doing a reverse donut on a snowy and empty parking lot(only did it three times then split), sometimes my passengers would be "funny" and put the car in neutral at a stop sign or red light and i wouldnt notice till i tried to go, and the daily abuse of a teenage lead foot driver.
    matt-im starting to think from the way you guys are talking, that is exactly what i may be thinking overdrive is.
  10. #10 Re: 02 GT engine/tranny issue?
    Allow me to explain: Overdrive is basically 4th gear on our cars. The car only goes into this by itself when you're cruising at 45+ mph. You can get it into overdrive by using cruise control at 44 mph as well.
    The abuse probably has weakened the tranny. Try getting the tranny fluid changed out to Dextron VI and the tranny filter changed.
    Doing as you've said would actually keep the car in second gear instead of forcing it to downshift into first. If you pressed the pedal all the way when below 35, the car downshifts into first. If you only press it halfway, the car will stay in second. Once you're above 35 MPH, no matter how far you press the pedal down, the car won't shift into first.
    Now if you press the pedal PAST halfway when doing below 35 the car WILL kick down into first which might be what you're refering to as overdrive.
  11. #11 Re: 02 GT engine/tranny issue?
    Upstate, NY
    That could be it, and the more i think about it when i drive, the more i notice it drops down a gear then revs like crazy. Im hoping just a tranny flush and filter change is needed.
  12. #12 Re: 02 GT engine/tranny issue?
    Thats normal if you're pushing the pedal to the floor. It will downshift to get the engine spinning to where its supposed to make the most power.
  13. #13 Re: 02 GT engine/tranny issue?
    Upstate, NY
    Well apparently according to the dealer tech's. Its the catalytic converter! ?
  14. #14 Re: 02 GT engine/tranny issue?
    GTP Level Member SuperSport's Avatar
    Michigan
    Exactly. Gm had a campaign for the 01 and 02 GT's where the converters block up. My car wouldnt go over 20mph when mine plugged. Go to the dealer in person and have them look up campaign #05551. As long as you have less than 120,000 miles the dealer will change the cat and the downpipe free of charge. They changed mine, cleared my code all for $0.00
    Hope this helps.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  15. #15 Re: 02 GT engine/tranny issue?
    Upstate, NY
    DAM IT! My car has 138k........ And i bet the dealer knew the whole time and didnt say crap!
  16. #16 Re: 02 GT engine/tranny issue?
    Upstate, NY
    Well, i actually just scored a new catalytic converter for under $220 at auto zone. And its direct mount! The dealer ship wants almost $700 for the part and labor. ha.
  17. #17 Re: 02 GT engine/tranny issue?
    Wausau, WI
    dont pay the dealer to do it, if it is clogged and they wont pay for it take it to an exhaust shop or do it yourself
  18. #18 Re: 02 GT engine/tranny issue?
    Wausau, WI
    you can get a cat for 80.....get a high flow cat while you are buying one...
  19. #19 Re: 02 GT engine/tranny issue?
    Upstate, NY
    Its already bought. my car is stock, and not under my name, so im not gonna worry to much about upgrades until i own it.
    The plan to install is take it to my vocational school tmw, i get out of my class for the day to work on my car, and its free to do. It seems simple enough to do.
  1. OK Here We go..Replacing Engine & Tranny
    By Sonny in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 10:41 PM
  2. lookin for tranny & engine!
    By gonzo915gp in forum General Tech Discussion
    Last Post: 07-19-2009, 09:52 PM
  3. Question: Tranny Torque Converter lock/unlock issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 05-31-2009, 09:54 PM
