Thread: coolant leak
Results 1 to 15 of 15
  1. #1 Re: coolant leak
    SE Level Member Skeeve's Avatar
    carneyville FL
    well, the leak im speaking of is on the actual firewall, i dont see where a plastic elbow would make a diff... unless im completely missing a hose? in which case i have a bigger problem... i can only see where the leak is coming from if im under the car, which makes it extremely difficult to take a picture with my phone.
    99 Grand Prix GT
  2. #2 Re: coolant leak
    wisconsin
    Nope, it is on the firewall, like the other poster said .. from what i have read before this is some kinda drain for the AC or rainwater or something .. the thing is if my heater core is leaking in the car can it communicate to this drain tube .. that is where the water is coming .. i know where that elbow is and it is right above the water pump, that is not it
  3. #3 Re: coolant leak
    Then you guys got different issues than I'm thinking of.
    If that's the heater box drain tube, then it shouldn't leak coolant. If coolant leaks out of the firewall you either have a bad heater core or a bad heater hose at the connection to the heater core.
  1. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  2. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  3. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  4. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  5. Opinions on possible coolant leak
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 11:00 PM
